Installing newly painted steel wheels #259785
03/20/09 10:14 AM
03/20/09 10:14 AM
at large
moparphillie Offline OP
at large
I am ready to install my newly painted steel wheels on my 1965 Belvedere I. I am concerned that installing and torquing the new lug nuts in place will crack or " fracture " the paint around the ( 5 ) stud openings in each wheel. I am not going to run dog dish hub caps, so the center of each wheel and the lug nuts will be in plain view. Has anyone got any tips on how to do prepare the wheels so that the new paint is not damaged around the lug nuts, once installed ?
Thanks MOPARTS...
Re: Installing newly painted steel wheels [Re: moparphillie] #259786
03/20/09 10:17 AM
03/20/09 10:17 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
How long has it been since the wheels were painted?
Re: Installing newly painted steel wheels [Re: burdar] #259787
03/20/09 10:19 AM
03/20/09 10:19 AM
at large
at large
It has been quite a while since August, 2008.
Re: Installing newly painted steel wheels [Re: moparphillie] #259788
03/20/09 10:29 AM
03/20/09 10:29 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
As long as the wheels were prepped good enough before the paint went on I would think you should be fine. The paint is going to scratch where the nut contacts the wheel but that is just to be expected. You shouldn't have paint "flaking" off if the wheels were painted correctly.
Re: Installing newly painted steel wheels [Re: burdar] #259789
03/20/09 10:25 PM
03/20/09 10:25 PM
Great Lakes State
O
ONEBADBIRD Offline
ONEBADBIRD  Offline
O
Great Lakes State
I never had any trouble with my paint cracking or flaking off. Now I don't know what kind of paint you used, or how you applied it. With mine I sandblasted them then used rattle can etch primer and gloss back paint right after sandblasting and have been holding up well for about 3 years now. Like stated before the area where the lugnuts go gets rubbed of but thats to be expected. Jay
Re: Installing newly painted steel wheels [Re: ONEBADBIRD] #259790
03/20/09 10:29 PM
03/20/09 10:29 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
The paint will likely peel off under the lugnut taper. Watch how deeply the socket goes over the nut, and fill the socket accordingly if it's going to scratch the wheel. Not a bad idea to wrap something around the outside of the socket, but I have moments of paranoia like that...
Re: Installing newly painted steel wheels [Re: topside] #259791
03/20/09 11:29 PM
03/20/09 11:29 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Mine's OK
Re: Installing newly painted steel wheels [Re: Michael] #259792
03/20/09 11:43 PM
03/20/09 11:43 PM
at large
at large
The wheels were all sandblasted, primed and painted with PPG Acrylic Enamel so as to match the exterior paint on the car. The body shop that did the paint work laid the paint on pretty thick in the center portion of the wheel and I am concerned about having the paint crack, flake or fracture on the exposed portion of the wheel near the point where the lug nuts make contact with the tapered part of the wheels. I appreciate all comments, but I still am at a loss as to whether I can sand, scuff or do anything to the tapered portion of the wheels where the lug nuts will come in contact to prevent any paint damage on the outer, adjacent portion to the wheel's taper.
Thanks again MOPARTS...
