1969 Charger Headers? #2588014
12/06/18 12:18 PM
12/06/18 12:18 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Good Morning Everyone,
We just did power steering and power brake upgrades on a 1969 Charger RT. I am looking for advice on a good set of headers that will not need modification to install. Car has a stock 440 with A/C and Auto Trans.
Thanks in advance!!
Re: 1969 Charger Headers? [Re: jim6346] #2588029
12/06/18 01:00 PM
12/06/18 01:00 PM
Zombieland
Car Nut Online laugh2
Zombieland
Re: 1969 Charger Headers? [Re: jim6346] #2588158
12/06/18 05:43 PM
12/06/18 05:43 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
TTI does list what looks like a good set. At $750, are they worth the money? I've never used them.
Thanks,
Re: 1969 Charger Headers? [Re: jim6346] #2588196
12/06/18 06:38 PM
12/06/18 06:38 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Any header that you don't have to beat and bang on, or modify is worth that money. Hemi headers are $1000
Re: 1969 Charger Headers? [Re: jim6346] #2588326
12/06/18 11:15 PM
12/06/18 11:15 PM
tucson az
frank Offline
frank  Offline
tucson az
Thanks,
I have the TTI's on my 69 GTX 440, 4 speed PS. Fit perfect first time. I installed them with the car on jack stands in my garage. Slid in with no mods. I'm getting a set for my 68 Charger shortly. The quality is there but to me the ease of installation and fit is what makes them worth the bucks.
Frank
Re: 1969 Charger Headers? [Re: jim6346] #2588368
12/07/18 12:23 AM
12/07/18 12:23 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Cheap headers with thin flanges will eventually leak. The 2 center ports only have 2 bolts to hold the flange to the gasket. A 5/16" flange with a raised bead of weld will eventually warp.
TTI's are great headers.
Re: 1969 Charger Headers? [Re: jim6346] #2588482
12/07/18 09:55 AM
12/07/18 09:55 AM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Thanks everyone, TTI's on order!!
Re: 1969 Charger Headers? [Re: jim6346] #2588521
12/07/18 12:08 PM
12/07/18 12:08 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I've never tried TTI's but with the glowing reviews I'd say there a nice set...
I have Doug's on my 70 with a 383 in it...They've been on now since 2010 with about 16K on them...They show a little wear and tear and a little rust around the flanges...Best part is when I had to install a new starter it can be done without removing the header or any exhaust...
...FAFO...
Re: 1969 Charger Headers? [Re: jim6346] #2588619
12/07/18 02:59 PM
12/07/18 02:59 PM
jersey
Spaceman Spiff Offline
jersey
I hear blackjack makes a nice header...
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: 1969 Charger Headers? [Re: skicker] #2588653
12/07/18 04:14 PM
12/07/18 04:14 PM
moparx Offline
moparx  Offline
i never owned a set until this past carlisle. i got a killer deal on a set of 2"/2 1/8" stepped.
they are, indeed, a well made set of tubes. the reason they were so cheap was some BOZO did a HORRIBLE job of clearancing 6 of the 8 tubes just off the flange. really beat them but good ! flame
i'll hafta take a pic of them one of these days.
i'll fix them by sectioning in about a 2" piece of new pipe on the tubes. but for the price, i could'nt leave them there.
beer
Re: 1969 Charger Headers? [Re: jim6346] #2589013
12/08/18 01:24 PM
12/08/18 01:24 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
I have put TTI headers on all my Mopars that have headers. You can utilize the factory spark plug wire brackets attached to the lower head bolts to help route the plug wires underneath the headers.. Then they will come up from underneath and the boots will attach to the spark plugs rather well with clearance. The closest one really is #5. Be prepared like I have mentioned here for plug wire clearances. Also, get a mini-starter..
Troy
Houston Mopar Connection Club
Re: 1969 Charger Headers? [Re: jim6346] #2589026
12/08/18 01:57 PM
12/08/18 01:57 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
TTI, Dougs (Thorley?) and Schumacher headers are made out of high quality thick steel and when their raw headers rust its a surface rust. When the cheap headers rust its a delamination crusty crumbly disintegration rust. Even the super expensive Hooker Super Comps will rot away if not ceramic coated inside and out.
Keep old mopars alive.
Re: 1969 Charger Headers? [Re: jim6346] #2589028
12/08/18 02:07 PM
12/08/18 02:07 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
I won't use nothing but tti exhaust. I have a set of 2" headers and 3" exhaust on my 65 coronet; perfect easy fit.
Re: 1969 Charger Headers? [Re: lewtot184] #2589031
12/08/18 02:34 PM
12/08/18 02:34 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
A story on my TTI 2-1/8 Hemi headers. I got them, beautiful. Read the instructions, drivers side, unbolt motor mount, raise engine 2", insert header. Yeah right, like that is going to clear the power steering chuck! I lay under the car cussing the obviously lying S-O-S who wrote the instructions, until I actually tried to insert said header into that impossibly tight cranny. It went right in!!! Unbelievable! I have installed a bunch of headers in my time and this was the first pair that not only went right in, but required no dings, dents, or modifications at all. That sure helped take some of the sting out of the 1K price tag! Quality, U.S. made product that makes my Mexican made Hooker SC's look sad.
Re: 1969 Charger Headers? [Re: jim6346] #2597281
12/26/18 07:44 PM
12/26/18 07:44 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
Hi Everyone, hope you all had a great Christmas
Just want to follow up on this. We ordered the TTI headers and
they fit like a glove. I have never had a header install go so
easy, and they included all the gaskets and hardware!! Well
worth the money!!
Hope everyone has a Happy New Year, stay safe.
jim
