Re: ELEPHANT EARS
[Re: A/MP]
#2596115
12/24/18 02:17 AM
12/24/18 02:17 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
ive ran them on a couple of 10 and 9 second b- body cars but i also ran a mid plate.no problems.
Re: ELEPHANT EARS
[Re: A/MP]
#2596122
12/24/18 02:27 AM
12/24/18 02:27 AM
Posts: 43,259 Bend,OR USA
Cab_Burge
Can they be fabricated and bolted directly to the head and avoid the water pump issues? Think about which BB Mopar heads have the same bolt pattern on the front of both heads My answer is none that I have seen or heard of going back the early 4 bolt valve cover heads with the bolt on rocker shaft holdowns Elephant ears can cause leaks on the water pump gaskets if there not tied down really well, I've always used two bolt on the frame brackets on both sides after finding out the one bolt would cause leakage on the gaskets
Re: ELEPHANT EARS
[Re: A/MP]
#2596124
12/24/18 02:30 AM
12/24/18 02:30 AM
Posts: 20,201 Park Forest, IL
slantzilla
Park Forest, IL
I had a pair on my 383 Dart. They go behind the water pump just like a motor plate. I took my pump housing to a machine shop and had .250 milled off of it so the pulleys still lined up.
Re: ELEPHANT EARS
[Re: A/MP]
#2596374
12/24/18 05:24 PM
12/24/18 05:24 PM
Posts: 2,117 Byron, NY
W.I.N. Racing
Byron, NY
Elephant ears in my experience cause water leaks and loosen due to engine movement. A one pc is superior to ears
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: ELEPHANT EARS
[Re: W.I.N. Racing]
#2596389
12/24/18 05:52 PM
12/24/18 05:52 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Most of us old time racers ran Elephant ears for years running 9's and 10's in the 1/4. Would I now, NO. Not when nice plates like Andy's are available. I bought my 4th plate from Andy and will be upgrading the 1/4 inch piece of crap holding my small block in this Winter after I freshen the engine. I gave my two sets of big block elephant ears away.
Re: ELEPHANT EARS
[Re: A/MP]
#2596490
12/24/18 09:08 PM
12/24/18 09:08 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Don't wast your money on elephant ears, been there done that. I have Andy F plates on both of my rides.
Re: ELEPHANT EARS
[Re: A/MP]
#2597079
12/26/18 11:23 AM
12/26/18 11:23 AM
Posts: 1,463 Martinsville, IN
cdwmotorsports
Martinsville, IN
While I never had any issue with my elephant ears, I now have one of Andy's plates too. Elephant ears are in my scrap metal bin
eBay-cdwmotorsports
Re: ELEPHANT EARS
[Re: A/MP]
#2597102
12/26/18 12:54 PM
12/26/18 12:54 PM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Ran the ears on my Challenger hemi stick 538s 9 second car. Used a cut water pump cast iron. Did not have any problems with leaks. If you are starting anew use a front plate and if you can a mid plate it is just a much better set up. Ears are just easier to install putting the motor in. Attaching a motor plate to the cage and frame just makes more sense to stiffen things up and things not moving around on a pass. The plate can also be used to attach other things to it in a closer location to the motor.
1971 HEMI E BODY REGISTRY
Re: ELEPHANT EARS
[Re: A/MP]
#2597416
12/27/18 02:09 AM
12/27/18 02:09 AM
Posts: 12,589 Great Neck,LI,new york
hemi-itis
Ears are 2 piece and a plate ran the ears they would constantly get loose and move around and eventually leak.The plate is the way to go and a midplate is a big plus!
Re: ELEPHANT EARS
[Re: Cab_Burge]
#2597785
12/27/18 10:46 PM
12/27/18 10:46 PM
eh100
eh100
Made my own....had midplate....never leaked....reverse cooling flow
Re: ELEPHANT EARS
[Re: Cab_Burge]
#2598438
12/29/18 04:55 PM
12/29/18 04:55 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
That's what I did. Drove my car regularly for 10 years, beat on it, never touched the gaskets never had a leak....
CrAzYMoPaRGuY
