ELEPHANT EARS #2596109
12/24/18 02:04 AM
12/24/18 02:04 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Well aware of the plates on the market. Any shortcomings with the elephant ears?
Re: ELEPHANT EARS [Re: A/MP] #2596115
12/24/18 02:17 AM
12/24/18 02:17 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
ive ran them on a couple of 10 and 9 second b- body cars but i also ran a mid plate.no problems.
Re: ELEPHANT EARS [Re: A/MP] #2596118
12/24/18 02:20 AM
12/24/18 02:20 AM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
Can they be fabricated and bolted directly to the head and avoid the water pump issues?
Re: ELEPHANT EARS [Re: A/MP] #2596122
12/24/18 02:27 AM
12/24/18 02:27 AM
Think about which BB Mopar heads have the same bolt pattern on the front of both heads work scope
My answer is none that I have seen or heard of going back the early 4 bolt valve cover heads with the bolt on rocker shaft holdowns shruggy
Elephant ears can cause leaks on the water pump gaskets if there not tied down really well, I've always used two bolt on the frame brackets on both sides after finding out the one bolt would cause leakage on the gaskets shruggy
Re: ELEPHANT EARS [Re: A/MP] #2596124
12/24/18 02:30 AM
12/24/18 02:30 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I had a pair on my 383 Dart. They go behind the water pump just like a motor plate. I took my pump housing to a machine shop and had .250 milled off of it so the pulleys still lined up.
Re: ELEPHANT EARS [Re: A/MP] #2596184
12/24/18 10:02 AM
12/24/18 10:02 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I think the 2 piece plates are more susceptible to twisting and leaks than a 1 piece. If you can tie them to keep from twisting, either on a head bolt, or the boss near the oil pump pad, it would help keep the twist motion in check.
Re: ELEPHANT EARS [Re: A/MP] #2596374
12/24/18 05:24 PM
12/24/18 05:24 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Elephant ears in my experience cause water leaks and loosen due to engine movement. A one pc is superior to ears twocents
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: ELEPHANT EARS [Re: W.I.N. Racing] #2596389
12/24/18 05:52 PM
12/24/18 05:52 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Most of us old time racers ran Elephant ears for years running 9's and 10's in the 1/4. Would I now, NO. Not when nice plates like Andy's are available. I bought my 4th plate from Andy and will be upgrading the 1/4 inch piece of crap holding my small block in this Winter after I freshen the engine. I gave my two sets of big block elephant ears away.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: ELEPHANT EARS [Re: A/MP] #2596490
12/24/18 09:08 PM
12/24/18 09:08 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Don't wast your money on elephant ears, been there done that. I have Andy F plates on both of my rides.
Re: ELEPHANT EARS [Re: A/MP] #2597079
12/26/18 11:23 AM
12/26/18 11:23 AM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
While I never had any issue with my elephant ears, I now have one of Andy's plates too. Elephant ears are in my scrap metal bin
eBay-cdwmotorsports
Re: ELEPHANT EARS [Re: A/MP] #2597102
12/26/18 12:54 PM
12/26/18 12:54 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
Ran the ears on my Challenger hemi stick 538s 9 second car. Used a cut water pump cast iron. Did not have any problems with leaks. If you are starting anew use a front plate and if you can a mid plate it is just a much better set up. Ears are just easier to install putting the motor in. Attaching a motor plate to the cage and frame just makes more sense to stiffen things up and things not moving around on a pass. The plate can also be used to attach other things to it in a closer location to the motor.
1971 HEMI E BODY REGISTRY
Re: ELEPHANT EARS [Re: A/MP] #2597416
12/27/18 02:09 AM
12/27/18 02:09 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Ears are 2 piece and a plate ran the ears they would constantly get loose
and move around and eventually leak.The plate is the way to go and a midplate is a big plus!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: ELEPHANT EARS [Re: A/MP] #2597449
12/27/18 04:28 AM
12/27/18 04:28 AM
If you do decide to use the ears try using studs with them and leave the nuts loose until the weight of the motor is on the ears and frame and the tighten up the nuts, that may help you stop leaks from the gaskets moving around scope wrench twocents
Re: ELEPHANT EARS [Re: Cab_Burge] #2597785
12/27/18 10:46 PM
12/27/18 10:46 PM
E
eh100
eh100
E
Made my own....had midplate....never leaked....reverse cooling flow
Re: ELEPHANT EARS [Re: Cab_Burge] #2598438
12/29/18 04:55 PM
12/29/18 04:55 PM
Canada
CrAzYMoPaRGuY Offline
Canada
That's what I did. Drove my car regularly for 10 years, beat on it, never touched the gaskets never had a leak....
CrAzYMoPaRGuY
Re: ELEPHANT EARS [Re: Cab_Burge] #2598490
12/29/18 07:00 PM
12/29/18 07:00 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
This is how i did mine. i used the 2 piece ears for 15 years with gaskets made from a beer carton cardboard, coated them with grease on install & bolted them up. i ran this combo for 15 vyears, never ever had a leak at this point. I found the 2 piece was more user friendly than my current 1 piece mount i'm using on my new combo, i'm thinking of cutting them in half at the next freshen up. I had one of Andys plates but decided not to use as they limit the mounting point locations for alternator & vac pump & coil.
