Pro mod/chassis car transmission question
#2596070
12/24/18 12:51 AM
12/24/18 12:51 AM
Posts: 1,030 ohio
67mprfan
ohio
Okay forgive me for asking a dumb question about I'm watching SO no prep show and noticed some of them don't have trans tunnels or blankets to protect them from explosion please explain to me how this is safe..... BTW Happy Holidays to everyone
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
Re: Pro mod/chassis car transmission question
[Re: 67mprfan]
#2596099
12/24/18 01:48 AM
12/24/18 01:48 AM
Posts: 1,030 ohio
67mprfan
ohio
Okay that explains it .... still makes me nervous having it exposed like it is
[Re: FastmOp]
#2596125
12/24/18 02:31 AM
12/24/18 02:31 AM
Posts: 43,159 Bend,OR USA
Cab_Burge
The trans case is SFI certified That doesn't allow not having a trans and drive shaft cover at any NHRA race I've attended, that wouldn't get through tech and it is not safe either S.O. it made for TV isn't it
[Re: 67mprfan]
#2596241
12/24/18 01:00 PM
12/24/18 01:00 PM
Posts: 20,176 Park Forest, IL
slantzilla
Park Forest, IL
It seems to me that the missing aluminum tunnel probably would stop much shrapnel anyway, but the big open hole would scare the crap out of me if the car caught fire.
[Re: 67mprfan]
#2596264
12/24/18 01:37 PM
12/24/18 01:37 PM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
At the end of the day you're responsible for your own safety. Some tracks like national trail tech with a fine tooth comb. Bowling green tech is tossing the card out the window on your way by. At the no tech or poor tech tracks it scares me what you'll line up against some times.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: 67mprfan]
#2596267
12/24/18 01:39 PM
12/24/18 01:39 PM
Posts: 1,030 ohio
67mprfan
ohio
Thanks for the replies hope everyone has a wonderful Christmas
[Re: 67mprfan]
#2596277
12/24/18 01:51 PM
12/24/18 01:51 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
The tin would not stop any parts that could exit an sfi case/ bell. That being said, it would stop or slow any fluid mist/ fire. I would run it with tin for that fact alone. As far as tech, the tin would need to be off for a real tech inspection to occur. Whether or not it gets installed after tech would be up to the driver I would think.
[Re: 67mprfan]
#2596339
12/24/18 04:04 PM
12/24/18 04:04 PM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
There needs to be a floor of some sort. They can't just be open. Either a tunnel covering the area or a belly pan under the chassis. A belly pan with absorbent is actually required in ProMod with a torque converter. Driveshaft loops/tunnels and SFI cases as required. Also driver suit requirements may be different if there is an exposed transmission in the drivers compartment. Just because it's not required with proper cases, doesn't mean a person can't use a blanket on some of this stuff.
[Re: 67mprfan]
#2596372
12/24/18 05:18 PM
12/24/18 05:18 PM
Posts: 2,110 Byron, NY
W.I.N. Racing
Byron, NY
Pretty sure Ryans "Street" racer has all the required safety stuff, Belly pan, drive shaft tunnel. It is a Pro built car.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2596379
12/24/18 05:32 PM
12/24/18 05:32 PM
Cab_Burge
Pretty sure Ryans "Street" racer has all the required safety stuff, Belly pan, drive shaft tunnel. It is a Pro built car. BUT, he does not race it at any NHRA events that I know of Installing that carbon fiber wrap around the weld on the chassis makes it NHRA,SFI, illegal also
[Re: FastmOp]
#2596620
12/25/18 02:22 AM
12/25/18 02:22 AM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’m sure an onboard fire system would work better with things closed off instead of air and flames rushing in
[Re: FastmOp]
#2596637
12/25/18 03:34 AM
12/25/18 03:34 AM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have two Stroud systems in my car as well. I didn't consider racing it without them. When I wrecked in 2010 and rolled on my roof I had my hand on my fire system handle as I slide 1/2 mile on my roof. Halon so being I couldn’t get out of the car that we my last option. I would rather suffocate than burn to death
[Re: pittsburghracer]
#2596786
12/25/18 03:47 PM
12/25/18 03:47 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I would rather suffocate than burn to death Halon is strange stuff. My first experience with it was at the bottom end with a guy who set his onboard system off by accident. Me being the inquisitive type, I stuck my head in the car to see what it smelled like. Took a breath and there was nothing there. Like drowning without the water.
[Re: CMcAllister]
#2596794
12/25/18 04:17 PM
12/25/18 04:17 PM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I would rather suffocate than burn to death Halon is strange stuff. My first experience with it was at the bottom end with a guy who set his onboard system off by accident. Me being the inquisitive type, I stuck my head in the car to see what it smelled like. Took a breath and there was nothing there. Like drowning without the water. Some of our finishing departments in the steel mill had Halon systems under the equipment. If we were doing down-day maintenance and the alarms came on we had X amount of seconds to climb out. This was drummed into our heads.
