Cracked Head? 440 #2595991
12/23/18 10:14 PM
12/23/18 10:14 PM
Chicago
PurpleBeeper Offline OP
Chicago
So, I've got the valve covers off (440) & just adjusted the valve lash. I notice that there is some coolant "weeping" out of the rear/lower valve cover bolt hole on the passenger side. Is that a cracked head?
I'm "hoping" those threads just run really, really close to the head cooling jacket & I tapped too deep cleaning up the threads.....but I'm just "hoping".
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Cracked Head? 440 [Re: PurpleBeeper] #2595995
12/23/18 10:23 PM
12/23/18 10:23 PM
AndyF Offline
AndyF  Offline
Original cast iron heads are well known for cracking. Not a big surprise, they are 50 years old and have had lots of heat cycles by now. If it is a very small crack you might be able to seal it up with a stop leak type of product.
Re: Cracked Head? 440 [Re: PurpleBeeper] #2596030
12/23/18 11:30 PM
12/23/18 11:30 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
If I'm not mistaken the lower end holes go into the water jacket that's why Ma Mopar put studs in the holes
Re: Cracked Head? 440 [Re: PurpleBeeper] #2596031
12/23/18 11:32 PM
12/23/18 11:32 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
The valve cover bolt holes don't (normally), at least on any iron big block head I've ever had. confused Only the exhaust port holes...
Re: Cracked Head? 440 [Re: PurpleBeeper] #2596041
12/23/18 11:44 PM
12/23/18 11:44 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It's not unknown for valve cover boltholes to hit water. Not supposed to but stuff happens.
Don't be the exception.
Re: Cracked Head? 440 [Re: Supercuda] #2596071
12/24/18 12:54 AM
12/24/18 12:54 AM
IL
BlwnCrcab Offline
BlwnCrcab  Offline
IL
I had on with a broken vc bolt
when I drilled it out went too far hit water
didn't leak w bolt or stud in it
Re: Cracked Head? 440 [Re: PurpleBeeper] #2596141
12/24/18 02:59 AM
12/24/18 02:59 AM
If it is leaking fix it now, it won't fix itself work whistling grin
You might want to use some two part epoxy, JB weld or?, on a stud for that hole, drain the radiator first and clean that hole out thoroughly first though before starting to patch it up up twocents
Re: Cracked Head? 440 [Re: PurpleBeeper] #2596268
12/24/18 01:40 PM
12/24/18 01:40 PM
Chicago
Chicago
Thanks everyone. I could not see any visible cracks & the engine has been running strong. I put some RTV silicone in that hole before screwing in the valve cover bolt....we'll see. No sign of antifreeze in the oil.
Re: Cracked Head? 440 [Re: PurpleBeeper] #2600984
01/03/19 03:26 PM
01/03/19 03:26 PM
an8sec70cuda Offline
I had a 906 head that one of the bottom corner valve cover bolts went into a water jacket. A little sealer on that bolt and no problems.
CHIP
'06 GMC 2500HD LBZ Duramax
