Testing Electronic Ignition Compnents #2594920
12/21/18 02:20 AM
12/21/18 02:20 AM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Are there any parts stores that can test ECU or electronic modules in distributors?
Abe Lincoln
Re: Testing Electronic Ignition Compnents [Re: dart4forte] #2594925
12/21/18 02:34 AM
12/21/18 02:34 AM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
I have tried the big chain places and no dice. I was told that you have to have use the factory Chrysler diagnostic tester. There may be an independent electric shop around that may have an old piece of equipment to test them.
Re: Testing Electronic Ignition Compnents [Re: dart4forte] #2594956
12/21/18 08:17 AM
12/21/18 08:17 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Distributors can be spun by hand quickly. With an AC voltmeter connected voltage (millivolt scale) will increase with speed of rotation. Resistance should measure approximately 270 ohms across the terminals.
Doug
Re: Testing Electronic Ignition Compnents [Re: dart4forte] #2594983
12/21/18 11:50 AM
12/21/18 11:50 AM
VA
dragon slayer Offline
VA
Service manual has a procedure to help isolate issues, by checking for continuity through system. Makes sure ignition system good, wires good, coil in distributor ohms ok, ballast resistor ok, good ground on Electronic box. But in the end the driving test once it starts. Seen boxes start cars, but not spark right at RPM. G
Re: Testing Electronic Ignition Compnents [Re: dart4forte] #2594984
12/21/18 11:51 AM
12/21/18 11:51 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Somewhere I had/have a booklet put out by Wells that went thru how to test various stuff like that.
I don't recall what all was covered, other than the pickup in a Mopar distributor, been 20+ years since I used it.
FOUND IT
Don't be the exception.
Re: Testing Electronic Ignition Compnents [Re: Supercuda] #2595035
12/21/18 01:13 PM
12/21/18 01:13 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
FOUND IT
Thank you, thank you! up
Re: Testing Electronic Ignition Compnents [Re: Supercuda] #2595056
12/21/18 01:53 PM
12/21/18 01:53 PM
moparx Offline
moparx  Offline
you jogged my memory that i have that book as well. now i gotta find mine.
beer
Re: Testing Electronic Ignition Compnents [Re: dart4forte] #2595068
12/21/18 02:24 PM
12/21/18 02:24 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
Common sense is a flower that does not grow in everybody's garden
Re: Testing Electronic Ignition Compnents [Re: moparx] #2595070
12/21/18 02:25 PM
12/21/18 02:25 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
beer
Now you can have it in PDF form too.
Re: Testing Electronic Ignition Compnents [Re: dart4forte] #2595118
12/21/18 04:41 PM
12/21/18 04:41 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
When I started wrenching in 1982 I bought a Blue Point MT133A off the Snap On truck. It's small and easy to use to pinpoint electronic ignition failures.
https://www.ebay.com/itm/Blue-Point-Tool...275.c4#viTabs_0
Re: Testing Electronic Ignition Compnents [Re: Ply72rr] #2595206
12/21/18 09:02 PM
12/21/18 09:02 PM
Mesa, Arizona
Mesa, Arizona
Did a net search. Found this
http://dave78chieftain.com/Ignition_Syste.html
I checked for 12 volts to the number one pin receptacle. Nothing. Same for number 2 pin, same result. I checked for voltage at the ballast resistor and I’m good there. Looks like it’s the harness. Just for shits and grins I went ahead and ordered one last night just in case.
Abe Lincoln
Re: Testing Electronic Ignition Compnents [Re: dart4forte] #2595246
12/21/18 10:16 PM
12/21/18 10:16 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The harness is simple. 2 wires from the ignition box to the distributor. One wire to the negative side of the coil. Check all 3 with an ohm meter. Ignition power to the box an positive side of the coil. The 5th wire at the ignition box does nothing.
Doug
Re: Testing Electronic Ignition Compnents [Re: dvw] #2595268
12/21/18 10:59 PM
12/21/18 10:59 PM
What DVW said, confirm everything is getting fed in ign1 (run)/ign2 (crank), the coil pri/sec & ballast have continuity, pickup generating AC voltage & gap is acceptable/box & engine is grounded. all that is left is the box itself (& items can check OK when cold then act up when warmed up). EDIT & a terminal/connection can be loose/poor continuity.
Re: Testing Electronic Ignition Compnents [Re: dart4forte] #2595306
12/22/18 12:20 AM
12/22/18 12:20 AM
Phoenix, AZ
Belvedere1 Offline
Belvedere1  Offline
Phoenix, AZ
Is this on the 300?
Re: Testing Electronic Ignition Compnents [Re: Supercuda] #2595477
12/22/18 02:06 PM
12/22/18 02:06 PM
moparx Offline
moparx  Offline
beer
i do now ! thanks to you ..... up
i bet i still find mine in the last place i look. biggrin
beer
Re: Testing Electronic Ignition Compnents [Re: Belvedere1] #2595753
12/23/18 01:02 PM
12/23/18 01:02 PM
Mesa, Arizona
Mesa, Arizona
Originally Posted By Belvedere1
Is this on the 300?
Yes
Abe Lincoln
