Testing Electronic Ignition Compnents
#2594920
12/21/18 02:20 AM
12/21/18 02:20 AM
Posts: 16,150 Mesa, Arizona
dart4forte
Mesa, Arizona
Are there any parts stores that can test ECU or electronic modules in distributors?
Abe Lincoln
Re: Testing Electronic Ignition Compnents
[Re: dart4forte]
#2594984
12/21/18 11:51 AM
12/21/18 11:51 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Somewhere I had/have a booklet put out by Wells that went thru how to test various stuff like that. I don't recall what all was covered, other than the pickup in a Mopar distributor, been 20+ years since I used it. FOUND IT
[Re: Supercuda]
#2595035
12/21/18 01:13 PM
12/21/18 01:13 PM
Posts: 10,735 North Dakota
6PakBee
North Dakota
Somewhere I had/have a booklet put out by Wells that went thru how to test various stuff like that. I don't recall what all was covered, other than the pickup in a Mopar distributor, been 20+ years since I used it. FOUND IT Thank you, thank you!
[Re: moparx]
#2595070
12/21/18 02:25 PM
12/21/18 02:25 PM
Supercuda
About to go away
About to go away
up yours
you jogged my memory that i have that book as well. now i gotta find mine. Now you can have it in PDF form too.
[Re: Ply72rr]
#2595206
12/21/18 09:02 PM
12/21/18 09:02 PM
dart4forte
Mesa, Arizona
Did a net search. Found this http://dave78chieftain.com/Ignition_Syste.htmlI checked for 12 volts to the number one pin receptacle. Nothing. Same for number 2 pin, same result. I checked for voltage at the ballast resistor and I’m good there. Looks like it’s the harness. Just for shits and grins I went ahead and ordered one last night just in case.
Abe Lincoln
[Re: dvw]
#2595268
12/21/18 10:59 PM
12/21/18 10:59 PM
RapidRobert
What DVW said, confirm everything is getting fed in ign1 (run)/ign2 (crank), the coil pri/sec & ballast have continuity, pickup generating AC voltage & gap is acceptable/box & engine is grounded. all that is left is the box itself (& items can check OK when cold then act up when warmed up). EDIT & a terminal/connection can be loose/poor continuity.
