E Body Door glass up stop brackets #2594795
12/20/18 08:34 PM
12/20/18 08:34 PM
New York
flitesweep Offline OP
New York
I am installing the regulators/door glass/brackets on a 1970 Cuda and find there are no door glass up stop holes with the factory nut and alignment tab that allows you to install the brackets. Did something change in later year production cars where this was eliminated or relocated? The doors are original Chrysler parts but I do not know what year car they came off of. It looks like I can drill the holes and install a threaded insert but am curious if someone else has had this issue and what they did to resolve it.
Re: E Body Door glass up stop brackets [Re: flitesweep] #2594797
12/20/18 08:41 PM
12/20/18 08:41 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I know the early 70 Cuda doors were different from the 71s.Inside braceing for one.Haven't checked the up stops yet.
Re: E Body Door glass up stop brackets [Re: flitesweep] #2594800
12/20/18 08:49 PM
12/20/18 08:49 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Do you have a photo of the door from the inside with the inner door panel off?
Re: E Body Door glass up stop brackets [Re: Alaskan_TA] #2594826
12/20/18 10:02 PM
12/20/18 10:02 PM
New York
New York
I could probably send you a photo tomorrow if you provide an email., The inner door looks identical to any other Cuda door. the area where the up stop brackets go are the same as well, just minus the hole/threaded nut as I described in the original post.
Re: E Body Door glass up stop brackets [Re: flitesweep] #2594834
12/20/18 10:17 PM
12/20/18 10:17 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1970 doors have more holes at the bottom for the plastic interior door panel clips than later doors, so it is an easy way to ID the 1970 only doors.
Re: E Body Door glass up stop brackets [Re: flitesweep] #2594918
12/21/18 02:13 AM
12/21/18 02:13 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Another easy way is how the window sweep felts are attached... slots for clips or screw holes. That's how I id them.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
