Later 440's have sodium filled valves??
#2594013
12/18/18 11:22 PM
12/18/18 11:22 PM
Posts: 848 Avondale AZ
Prodart440
Avondale AZ
My brother told me he heard the later 440 engines used sodium filled valves, and were not designed to run at higher RPM. I bought one from him out of a 78 motor home for my Coronet. Just wanted to comfirm, is this rumor true or is it fake news?
Aaron
68 Roadrunner 383/AT 69 Dart GT Conv. 383/AT 05 Dodge Ram 4x4 Cummins 06 GoManGo R/T Daytona #757 68 Coronet 440
Re: Later 440's have sodium filled valves??
[Re: Prodart440]
#2594058
12/19/18 01:06 AM
12/19/18 01:06 AM
Posts: 43,163 Bend,OR USA
Cab_Burge
I've never heard of any Mopar engines coming with those valves stock or as a option, I started running and working on Mopar V8 in 1964 The only motors I have ever heard and know that had those valves stock where in the Ford FE 427 race motors for NASCAR Me thinks your brother is being mislead on this Mopar made many different versions of H.D. truck, H.D. industrial and marine motors as well as all out race motors, I don't think any of them had those type valves in them from the factory, maybe I'm wrong
[Re: Prodart440]
#2594073
12/19/18 01:37 AM
12/19/18 01:37 AM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Only old Mopars with sodium exh valves were extra hd ind engines like a 318-3 with a 7/16 valve stem. Present 6.4L also have them.
Leave the gun.......take the Cannoli's....Mike
[Re: Prodart440]
#2594105
12/19/18 02:50 AM
12/19/18 02:50 AM
Prodart440
Avondale AZ
Maybe he was mis-led by the industrial used one. Thanks for all the information!!
Aaron
[Re: BlwnCrcab]
#2594363
12/19/18 06:21 PM
12/19/18 06:21 PM
Cab_Burge
I have a 354 Hemi out of a boat has a sticker on valve cover says it has sodium filled valves in it I remember a old time mechanic saying the same thing on the H.D. 354 Hemi truck motors with 1/2 stem valves being sodium filled back then, prior to 1959
[Re: dOrk !]
#2594509
12/20/18 12:14 AM
12/20/18 12:14 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
The industrial/truck and motor home 413 and 361 motors had sodium filled exhaust valves ....7/16 stem size sounds about right Did not know that. Thanks , Ron
[Re: Prodart440]
#2594523
12/20/18 01:11 AM
12/20/18 01:11 AM
Posts: 8,395 Highland, MI.
Sunroofcuda
Highland, MI.
So I gotta ask - are they hollow & then filled with sodium? I'm guessing this would reduce operating temp??? Would a "hollow" valve be weaker though? (I'm not an engine guy...)
[Re: Prodart440]
#2594582
12/20/18 04:41 AM
12/20/18 04:41 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
The sodium transfers the heat out of the valve on the exhaust and puts it into the guide. Airplanes have been using them since the 30's
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Prodart440]
#2594641
12/20/18 12:32 PM
12/20/18 12:32 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Lol, TRW is too cheap for a spellchecker.
[Re: Supercuda]
#2594646
12/20/18 12:47 PM
12/20/18 12:47 PM
Posts: 22,696 Bitopia
jcc
Bitopia
My old International truck gas 392 had them.
Was there a loose weight/plunger inside to facilitate fluid move? Thought I remember a click when shaken,
[Re: Prodart440]
#2594651
12/20/18 12:53 PM
12/20/18 12:53 PM
Supercuda
About to go away
About to go away
up yours
that was the pea rattling around in your head.
