Later 440's have sodium filled valves?? #2594013
12/18/18 11:22 PM
12/18/18 11:22 PM
Avondale AZ
Prodart440 Online work OP
Prodart440  Online Work OP
Avondale AZ
My brother told me he heard the later 440 engines used sodium filled valves, and were not designed to run at higher RPM. I bought one from him out of a 78 motor home for my Coronet. Just wanted to comfirm, is this rumor true or is it fake news?
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Later 440's have sodium filled valves?? [Re: Prodart440] #2594058
12/19/18 01:06 AM
12/19/18 01:06 AM
I've never heard of any Mopar engines coming with those valves stock or as a option, I started running and working on Mopar V8 in 1964 shruggy
The only motors I have ever heard and know that had those valves stock where in the Ford FE 427 race motors for NASCAR work scope
Me thinks your brother is being mislead on this twocents
Mopar made many different versions of H.D. truck, H.D. industrial and marine motors as well as all out race motors, I don't think any of them had those type valves in them from the factory, maybe I'm wrong shruggy
Re: Later 440's have sodium filled valves?? [Re: Prodart440] #2594062
12/19/18 01:10 AM
12/19/18 01:10 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have heard the same as Cab. Never heard of any 440's with them but have heard the Ford 427 FE and maybe the 427 Cammer had them ? Ron
Re: Later 440's have sodium filled valves?? [Re: Cab_Burge] #2594063
12/19/18 01:12 AM
12/19/18 01:12 AM
IL
BlwnCrcab Offline
BlwnCrcab  Offline
IL
I have a 354 Hemi out of a boat
has a sticker on valve cover
says it has sodium filled valves in it
Re: Later 440's have sodium filled valves?? [Re: BlwnCrcab] #2594071
12/19/18 01:24 AM
12/19/18 01:24 AM
KY USA
mopargem Offline
mopargem  Offline
KY USA
The early 79 back Ferrari 308 had sodium filled valves and ran high rpm
Re: Later 440's have sodium filled valves?? [Re: Prodart440] #2594073
12/19/18 01:37 AM
12/19/18 01:37 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Only old Mopars with sodium exh valves were extra hd ind engines like a 318-3 with a 7/16 valve stem. Present 6.4L also have them.
Leave the gun.......take the Cannoli's....Mike
Re: Later 440's have sodium filled valves?? [Re: Prodart440] #2594075
12/19/18 01:48 AM
12/19/18 01:48 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
The industrial/truck and motor home 413 and 361 motors had sodium filled exhaust valves ....7/16 stem size sounds about right
Re: Later 440's have sodium filled valves?? [Re: dOoC] #2594078
12/19/18 01:51 AM
12/19/18 01:51 AM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Damb Doc Im proud of you! A normal reply and it sounds like you really do know your Mopars up
Re: Later 440's have sodium filled valves?? [Re: Prodart440] #2594080
12/19/18 01:55 AM
12/19/18 01:55 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Hey HAY .... I always post GEMS ! penguin
Re: Later 440's have sodium filled valves?? [Re: Prodart440] #2594105
12/19/18 02:50 AM
12/19/18 02:50 AM
Avondale AZ
Avondale AZ
Maybe he was mis-led by the industrial used one. Thanks for all the information!!
Aaron
68 Coronet 440
Re: Later 440's have sodium filled valves?? [Re: Prodart440] #2594174
12/19/18 11:53 AM
12/19/18 11:53 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Anyone heard of the present 6.4L having a failure of one of the modern sodium filled valves?
Re: Later 440's have sodium filled valves?? [Re: BlwnCrcab] #2594363
12/19/18 06:21 PM
12/19/18 06:21 PM
I remember a old time mechanic saying the same thing on the H.D. 354 Hemi truck motors with 1/2 stem valves being sodium filled back then, prior to 1959 shruggy
Re: Later 440's have sodium filled valves?? [Re: dOoC] #2594509
12/20/18 12:14 AM
12/20/18 12:14 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Did not know that. Thanks , Ron
Re: Later 440's have sodium filled valves?? [Re: Prodart440] #2594523
12/20/18 01:11 AM
12/20/18 01:11 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
So I gotta ask - are they hollow & then filled with sodium? I'm guessing this would reduce operating temp??? Would a "hollow" valve be weaker though? (I'm not an engine guy...)
Re: Later 440's have sodium filled valves?? [Re: Sunroofcuda] #2594558
12/20/18 02:39 AM
12/20/18 02:39 AM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Yes hollow with huge stems and they lower operating temps H U G E !
Re: Later 440's have sodium filled valves?? [Re: Prodart440] #2594582
12/20/18 04:41 AM
12/20/18 04:41 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
The sodium transfers the heat out of the valve on the exhaust and puts it into the guide. Airplanes have been using them since the 30's
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Later 440's have sodium filled valves?? [Re: Prodart440] #2594594
12/20/18 08:24 AM
12/20/18 08:24 AM
USA
3
360view Offline
360view  Offline
3
USA
Rough rule of thumb used to be that
using a sodium filled exhaust valve
allows about +1 in compression ratio
on the same Octane fuel.
Ford 427s had so many failures of their particular sodium filled valves that the idea got a bad name that has lasted decades.
Re: Later 440's have sodium filled valves?? [Re: Prodart440] #2594641
12/20/18 12:32 PM
12/20/18 12:32 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Lol, TRW is too cheap for a spellchecker.
Don't be the exception.
Re: Later 440's have sodium filled valves?? [Re: Supercuda] #2594646
12/20/18 12:47 PM
12/20/18 12:47 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
My old International truck gas 392 had them.
Was there a loose weight/plunger inside to facilitate fluid move?
Thought I remember a click when shaken,
Re: Later 440's have sodium filled valves?? [Re: Prodart440] #2594651
12/20/18 12:53 PM
12/20/18 12:53 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
that was the pea rattling around in your head.
