Re: Starter issue with JW Ultrabell
[Re: Sammy]
#2594045
12/19/18 12:41 AM
12/19/18 12:41 AM
Posts: 2,837 Pattison Texas
CSK
Pattison Texas
the nose fits VERY tight in a machined hole in the bellhousing, is it possible the nose of the starter broke when installing? I had to hone the hole out on mine
[Re: Sammy]
#2594190
12/19/18 12:34 PM
12/19/18 12:34 PM
Posts: 4,359 Michigan
MarkZ
Worthy
Worthy
Are you using a mini starter? Mine wouldn't fit properly either, but I elected to mill the nose on the starter down a bit rather than modify the bell.
[Re: MarkZ]
#2594206
12/19/18 01:04 PM
12/19/18 01:04 PM
Posts: 2,558 S.E. Michigan
cl440
S.E. Michigan
Are you using a mini starter? Mine wouldn't fit properly either, but I elected to mill the nose on the starter down a bit rather than modify the bell. We did the same thing. Used a cut off wheel and removed the nose off the starter.
[Re: Sammy]
#2594234
12/19/18 02:07 PM
12/19/18 02:07 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Starter was snug going in but the starter did go all the way in and flush with the bellhousing. Why would the starter not engage with the ring gear right away? Misaligned. Very little aftermarket works without adjustment.
[Re: BobR]
#2594247
12/19/18 02:24 PM
12/19/18 02:24 PM
Posts: 20,111 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Everything needs checked and double checked. Hell my Keith Black block needed the side ground some for clearance even with a mini starter. It was rubbing and kicking it in crooked.
[Re: Dave Hall]
#2594271
12/19/18 03:11 PM
12/19/18 03:11 PM
Posts: 20,111 PA.
pittsburghracer
"Little"John
"Little"John
PA.
All of my powerglides (3) are switched over to ATI cases and bellhousings after cracking a case and blowing out fluid last year. 1.69 low gear, 1.80 low gear, and 1.98 low gear. Small block and big block bellhousings
[Re: MR_P_BODY]
#2594429
12/19/18 09:02 PM
12/19/18 09:02 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Something isnt on centerline.. ether the starter wheel or the drive is bent New starter,only thing changed was cutting off OE bellhousing and added JW Ultrabell. I'm wondering if the starter snout is tight going in, that might be causing the issue. Getting this starter out is virtually impossible with TTI headers. I think I'll have to remove the transmission to get the starter out. If that's the case, I 5hink I'm going to go back to factory bellhousing abd just put in an old case.
[Re: Sammy]
#2594445
12/19/18 09:42 PM
12/19/18 09:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You have 2 choices that I can see.. either you change the way the headers run or you change the trans.. myself I would reroute the headers but I do that stuff on my junk a lot.. good luck
