Getting RID OF that 2.7 in a Sebring vert ? .... !! #2592475
12/15/18 07:16 PM
12/15/18 07:16 PM
Florida STAYcation
dOOc Offline OP
The village idiot's idiot
dOOc  Offline OP
Florida STAYcation
....any EZ swaps out there? ...a bud found TWO of these cars SUPER CLEAN except for that junker-motor and I would like to consider one for meself .... what to do ? suggestions ??
Re: Getting RID OF that 2.7 in a Sebring vert ? .... !! [Re: dOOc] #2592500
12/15/18 08:14 PM
12/15/18 08:14 PM
A727Tflite Offline
A727Tflite  Offline
Put a 440 Super Stock motor in it and run GT class with it.
More fun than a 2.7.
whistling
Re: Getting RID OF that 2.7 in a Sebring vert ? .... !! [Re: dOOc] #2592507
12/15/18 08:29 PM
12/15/18 08:29 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Ask around if a 3.3, or 3.5 would bolt in, they are really good engines.
Re: Getting RID OF that 2.7 in a Sebring vert ? .... !! [Re: dOOc] #2592543
12/15/18 09:48 PM
12/15/18 09:48 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
At 14 years old it should have already nuked itself if it was going to... ? Did you pull the dipstick or see how nasty the coolant looks ?
I will not defend the design, it is a POS but supposedly they got them 'fixed' by 03-04.
The 2.7 reminds me a lot of the ultradrive transmission. Almost 30 years later and the ignorant armchair experts of the internet still swear every single one of them is a ticking time bomb that will fail without warning.
Re: Getting RID OF that 2.7 in a Sebring vert ? .... !! [Re: 135sohc] #2592552
12/15/18 10:27 PM
12/15/18 10:27 PM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
I've got a 2001 Intrepid with 279,xxx miles on it. Still going strong ... and with the original 2.7 engine!
Re: Getting RID OF that 2.7 in a Sebring vert ? .... !! [Re: dOOc] #2592620
12/16/18 01:04 AM
12/16/18 01:04 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Those cars came with the 2.4 4 banger, too. You could do a complete drop-out. The 2.4 is a good engine IMHO.
Master, again and still
Re: Getting RID OF that 2.7 in a Sebring vert ? .... !! [Re: dOOc] #2592716
12/16/18 12:57 PM
12/16/18 12:57 PM
RWG75
RWG75
maybe poke around www.sebringclub.net
I want to say I've seen it discussed over there but don't recall much detail as I was hunting for 200 (aka G3 sebring) info.
Re: Getting RID OF that 2.7 in a Sebring vert ? .... !! [Re: ] #2592776
12/16/18 02:47 PM
12/16/18 02:47 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The wifegod had a 2.7 convertible for 11 years, no issues EVER with the engine/trans. Only problems were the strut spacers in the rear made of aluminum, turned to dust in the rust belt and window motors, besides that not a hitch in the giddyup, all that ever needed to happen to keep those engines in good shape were oil changes on time every 3K miles... up
JB Rhinehart, Realist
A-Body's RULE!
Re: Getting RID OF that 2.7 in a Sebring vert ? .... !! [Re: dOOc] #2592830
12/16/18 04:20 PM
12/16/18 04:20 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
The 2.7 developed a bad reputation for several reasons. The earlier 2.7 Intrepids had the converters to close to the oil pan. This overheated the oil, causing problems. I have not heard of the Sebrings having this issue.
Most of the other issues with the 2.7's involved the timing chain and the components around the timing chain. The water pump is driven by the timing chain. If it fails, it dumps coolant into the oil. The tensioner for the timing chain would also fail causing a loss of oil pressure.
I believe Chrysler suggested changing the timing chain and all the related components every 100,000 miles. This can increase the odds of the engine holding together. There was also a spacer available on the aftermarket that was advertised as preventing the problems with the tensioner failing. I never installed one. I can't seem to find the advertisement now....
As Rhinodart mentioned, the 2.7's had small oil passages. Changing the oil frequently was also crucial to longevity.
The original question was about replacing the 2.7 with a better engine. In the Intrepids, the 2.7 could be replaced with the 3.5 engine. The 3.5 is in the same engine family, but has a better reputation. I have NOT heard of anyone installing a 3.5 in a Sebring.
Re: Getting RID OF that 2.7 in a Sebring vert ? .... !! [Re: QuickDodge] #2592958
12/16/18 09:58 PM
12/16/18 09:58 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Another important factor in the durability of the early 2.7s appears to be the way they were driven. Our local PD had a couple of Intrepids with 2.7s that went well over 200K each.
At the same, we were seeing them with 80k at the auctions that were knocking, had low oil pressure, or were inops.
It seems that the ones that were used for short hops around town and not getting the chance to fully warm up, suffered the worse. The ones (like the cop cars) that got to full temp and were able to spend enough time there, did okay with proper maintenance.
twocents
Re: Getting RID OF that 2.7 in a Sebring vert ? .... !! [Re: 135sohc] #2593985
12/18/18 10:20 PM
12/18/18 10:20 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I buy newer ones than that for pennys on the dollar because of blown 2.7s. I currently have in my fleet a 2006 magnum and 2010 charger, both of them got 3.5 swaps with real low miles by me. All the suposed fixes never fixed anything, the water pump still dribbles coolant in the oil and causes sludge that clogs up oil screens, and head return passages and wipes out bearings as well as about 700 feet of timing chains and plastic timing chain guides that break apart and allow the chains to jump bending lots of valves.
Re: Getting RID OF that 2.7 in a Sebring vert ? .... !! [Re: dOOc] #2594526
12/20/18 01:14 AM
12/20/18 01:14 AM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Yes, a 3.2 or 3.5 conversion is possible and has been done. Not quite a bolt in deal, but doable. Tom Vago used to have his own Sebring website and has done the swap. http://tom-viki.com/1C3EL75R62N/engine.html
Have fun as my 2000 was the biggest pain in the ass to work on of any car I have owned.
