Re: Getting RID OF that 2.7 in a Sebring vert ? .... !!
[Re: dOc !]
#2592620
12/16/18 01:04 AM
12/16/18 01:04 AM
Posts: 12,247 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Those cars came with the 2.4 4 banger, too. You could do a complete drop-out. The 2.4 is a good engine IMHO.
Master, again and still
[Re: dOc !]
#2592716
12/16/18 12:57 PM
12/16/18 12:57 PM
RWG75
RWG75
maybe poke around www.sebringclub.netI want to say I've seen it discussed over there but don't recall much detail as I was hunting for 200 (aka G3 sebring) info.
[Re: QuickDodge]
#2592958
12/16/18 09:58 PM
12/16/18 09:58 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Another important factor in the durability of the early 2.7s appears to be the way they were driven. Our local PD had a couple of Intrepids with 2.7s that went well over 200K each. At the same, we were seeing them with 80k at the auctions that were knocking, had low oil pressure, or were inops. It seems that the ones that were used for short hops around town and not getting the chance to fully warm up, suffered the worse. The ones (like the cop cars) that got to full temp and were able to spend enough time there, did okay with proper maintenance.
[Re: 135sohc]
#2593985
12/18/18 10:20 PM
12/18/18 10:20 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
At 14 years old it should have already nuked itself if it was going to... ? Did you pull the dipstick or see how nasty the coolant looks ?
I will not defend the design, it is a POS but supposedly they got them 'fixed' by 03-04.
The 2.7 reminds me a lot of the ultradrive transmission. Almost 30 years later and the ignorant armchair experts of the internet still swear every single one of them is a ticking time bomb that will fail without warning. I buy newer ones than that for pennys on the dollar because of blown 2.7s. I currently have in my fleet a 2006 magnum and 2010 charger, both of them got 3.5 swaps with real low miles by me. All the suposed fixes never fixed anything, the water pump still dribbles coolant in the oil and causes sludge that clogs up oil screens, and head return passages and wipes out bearings as well as about 700 feet of timing chains and plastic timing chain guides that break apart and allow the chains to jump bending lots of valves.
[Re: dOc !]
#2594526
12/20/18 01:14 AM
12/20/18 01:14 AM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
Yes, a 3.2 or 3.5 conversion is possible and has been done. Not quite a bolt in deal, but doable. Tom Vago used to have his own Sebring website and has done the swap. http://tom-viki.com/1C3EL75R62N/engine.htmlHave fun as my 2000 was the biggest pain in the ass to work on of any car I have owned.
