aluminum head with stock exhaust height #2593399
12/17/18 10:16 PM
12/17/18 10:16 PM
NY
moparmatt0 Offline OP
NY
Want to build a 400 block stroker for my 69 barracuda but I want to use the headers that are in the car now for the stocker motor.I want to buy a good set of heads and I was planning on buying the 440 source 500 inch rotating assemble.Any ideas are aprciated thanks Matt.
Re: aluminum head with stock exhaust height [Re: moparmatt0] #2593417
12/17/18 10:43 PM
12/17/18 10:43 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
C&C ported 440 source heads
Re: aluminum head with stock exhaust height [Re: moparmatt0] #2593434
12/17/18 11:01 PM
12/17/18 11:01 PM
AndyF Online content
AndyF  Online Content
Best value these days for a stroker engine would be Trick Flow 240 heads. You could also look at ported Stealth or Edelbrock heads but typically they'll end up costing more than the Trick Flow heads by the time you're done with them. You could also go with out of the box Stealth or Edelbrock heads but you'll give up some power over the Trick Flow heads.
Re: aluminum head with stock exhaust height [Re: AndyF] #2593441
12/17/18 11:05 PM
12/17/18 11:05 PM
NY
NY
Are the trick flow 240 good out of the box parts wise like springs and retainers and valves.
Re: aluminum head with stock exhaust height [Re: AndyF] #2593457
12/17/18 11:24 PM
12/17/18 11:24 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I agree BUT will his headers work with angle plugs ? mine wont
Re: aluminum head with stock exhaust height [Re: moparmatt0] #2593477
12/17/18 11:52 PM
12/17/18 11:52 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Then, I guess the first question is....... will angle plug heads work with his headers or not?
If that’s a “no”, then the choices are far fewer, and really just variations on a theme.
-84cc E street
-MP “452”
-Straight plug Speedmaster
-Stealth
Re: aluminum head with stock exhaust height [Re: moparmatt0] #2593480
12/17/18 11:54 PM
12/17/18 11:54 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
What brand headers are they
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: aluminum head with stock exhaust height [Re: moparmatt0] #2593611
12/18/18 05:38 AM
12/18/18 05:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I know my TTI 2" headers actually seem to have more room around the plugs with my angled plugs on my EZ heads then if they were straight plugs. I am very happy with the standard EZ heads I went with on my mild street combo. I got them from Dwayne and he just opened them up tp Max Wedge size on the intakes and cleaned them up. Course there was no Trick Flow heads when I put mine together in 2011. I don't know if the EZ heads are cheaper then the Trick Flows or if they flow as good as the Trick Flows but I believe Trick Flows are the only ones that come already CNC ported ? You can sorta tell in this pic if my plugs were straight they would be closer to the header tubes. Ron
Re: aluminum head with stock exhaust height [Re: moparmatt0] #2593774
12/18/18 03:01 PM
12/18/18 03:01 PM
Double checking the headers is the first thing to do. I've had a couple different sets of TTI headers on my car and both sets worked much better with angled plugs than straight plugs but that isn't true for all headers. Old school headers designed before angled plugs became popular won't work. So the OP will have to figure that out and and get back to us.
Re: aluminum head with stock exhaust height [Re: moparmatt0] #2593782
12/18/18 03:09 PM
12/18/18 03:09 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I've ran both the 440 source heads (non CNC) and now the Trick Flow 240s in a 75 Duster. Had 2" TTI on the 440 source heads and now went to 1 3/4" TTI with the Trick Flows. No issues with plugs with either setup.
Re: aluminum head with stock exhaust height [Re: moparmatt0] #2593839
12/18/18 04:19 PM
12/18/18 04:19 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
so TTI work with trick flow heads...
what other headers will work?
Dougs?
Hooker?
Hedman?
