68 Charger Tranny Trouble, I think. #2593436
12/17/18 11:03 PM
12/17/18 11:03 PM
Wattsburg, Pa
Dr V Offline OP
Dr V  Offline OP
Wattsburg, Pa
The car is my 1968 white charger 383. It has the original 727 in it with a 3300 stall. We put it in probably 15 years ago. I don't drive the car that often. lately when I start the car it warms up and then every time you step on the gas the car starts to lunge forward while it's in park. It almost seems like the transmission is engaging while it sits in park.. It's just not running right. Possible stall converter problem? Or do I have tranny trouble?. Doc
69 1/2 A12 BEE 4 spd
1968 Charger 383
1970 Roadrunner 440+6 Survivor
2019 Redeye
2005 FORD GT Red/White
2017 Viper ACR Extreme Red/White
1979 Branco Red/Red
2018 Porsche GT3 Miami
1971 440+6 Cuda 4 speed V2
2020 Sebring Orange Vette
1979 Chevy Boogie Hippie Van
Re: 68 Charger Tranny Trouble, I think. [Re: Dr V] #2593445
12/17/18 11:09 PM
12/17/18 11:09 PM
A727Tflite Offline
A727Tflite  Offline
Does it creep forward in neutral too?
Sounds like the rear clutch is dragging for some reason.
Another test - In reverse you likely wouldn’t know if this clutch is dragging unless the car is fighting itself and resisting reverse. The rear clutch should be off in reverse. How is reverse?
Most people see rear clutch issues first by - your complaint and creeping forward in neutral.
Check it out and let us know.
Re: 68 Charger Tranny Trouble, I think. [Re: A727Tflite] #2593456
12/17/18 11:24 PM
12/17/18 11:24 PM
Wattsburg, Pa
Dr V Offline OP
Dr V  Offline OP
Wattsburg, Pa
I will check reverse this week. Thank you for the Head Start. one more thing. When I am sitting in park and the car is up to temperature I step on the gas and it feels like I am power braking the car. The motor will not even rev properly. It's almost like I am power breaking the car but I'm still in park. Something is definitely engaged..
1968 Charger 383
2019 Redeye
1979 Branco Red/Red
Re: 68 Charger Tranny Trouble, I think. [Re: Dr V] #2593460
12/17/18 11:27 PM
12/17/18 11:27 PM
New Jersey
P
Powerflow Offline
Powerflow  Offline
P
New Jersey
Don't know if this applies, but I had one Mopar where the TV linkage rusted together and every time you stepped on the gas the trans tried to downshift. WD-40 and a few hammer taps fixed it.
Re: 68 Charger Tranny Trouble, I think. [Re: Dr V] #2593538
12/18/18 01:06 AM
12/18/18 01:06 AM
A727Tflite Offline
A727Tflite  Offline
Sure sounds like the rear clutch got toasted some how. Test that trans in neutral and then reverse and post your results.
Re: 68 Charger Tranny Trouble, I think. [Re: A727Tflite] #2593619
12/18/18 06:05 AM
12/18/18 06:05 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree as it sounds like welded rear clutches. Sounds like she will have to come out. Good luck , Ron
Re: 68 Charger Tranny Trouble, I think. [Re: Dr V] #2593820
12/18/18 03:48 PM
12/18/18 03:48 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
A little minor surgery is in order Doc.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 68 Charger Tranny Trouble, I think. [Re: 383man] #2593870
12/18/18 05:11 PM
12/18/18 05:11 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Or a weak Belleville allowed the piston to pop out of its bore and jam the clutch pack.
Re: 68 Charger Tranny Trouble, I think. [Re: John_Kunkel] #2594017
12/18/18 11:29 PM
12/18/18 11:29 PM
Wattsburg, Pa
Dr V Offline OP
Dr V  Offline OP
Wattsburg, Pa
Update.
So I start the car. Got up to temperature, and Tuned the carburetor to make sure everything was good. Mind you, this car has been off the road and not really driving much in the last 7 years. The car comes up to temperature, and it is lunging a little bit forward while it is in park. I put it in reverse and back out of the garage and then I went from drive to reverse hard a couple of times each way. Next thing you know everything is running free and the motor is revving properly in park. It almost felt like putting it in reverse and slamming it a couple of times each way broke whatever was in there loose. Something was bound up. I took the car down the road back and forth for about 20 minutes. All seems well. Is it possible for the clutch to disengage itself or get stuck? I don't know much about them.
1968 Charger 383
2019 Redeye
1979 Branco Red/Red
