452 casting valve springs? #2593227
12/17/18 04:18 PM
12/17/18 04:18 PM
Southern Oregon
toyotajeep Offline OP
Southern Oregon
I am weighing my options on my ultra-budget 440 build. I will be running around a .500 lift hydraulic cam. Typical street hot rod thing.
Is there a drop in spring that will work with stock retainers and seals etc.?
Most aftermarket springs seem to be around 1.5 OD, and my stock retainers are closer to 1.3...
I have researched some and I know I can buy a kit. Just trying to save some cash is all.
If there is not a spring that will drop in, is there a combo of spring and retainer that would work without machining?
I do have proper tools here for measuring installed height and spring tension.
Thank you for your help.
1989 Dodge Cummins & 1989 Dodge W-250
Re: 452 casting valve springs? [Re: toyotajeep] #2593290
12/17/18 06:41 PM
12/17/18 06:41 PM
God's Country Maryland
GODSCOUNTRY340 Offline
440 magnum springs will work with your retainers. I get mine on ebay from moparmtman.
item number 173648598089. Don't go with any higher than that .500 without having your guides cut down or you'll be bending pushrods.
Re: 452 casting valve springs? [Re: toyotajeep] #2593311
12/17/18 07:20 PM
12/17/18 07:20 PM
Southern Oregon
Southern Oregon
I haven’t been home to check a few things but it looks like the Eddy Sure seat springs might work. Just doing some thinking.
Re: 452 casting valve springs? [Re: toyotajeep] #2594443
12/19/18 09:33 PM
12/19/18 09:33 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Be sure to check the retainer to seal clearance.
