Getting 400 HP From A Smogger 440 #2593061
12/17/18 08:33 AM
12/17/18 08:33 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
I have a very good running 78 440 in my pickup. Can I get 400 hp or close without swapping pistons? I know compression is low. What can I do that will improve performance? I have headers on it now. I also have a Performer RPM intake with a 750 Holley to put on it. Right now I'm running 516 heads that have larger exhaust valves in them. I do have a set of fresh 346 and 452 heads on the shelf. Cam choices? Current set up now is an automatic, 3:23 gears, and I'm running 26.5 in tall tires.
Re: Getting 400 HP From A Smogger 440 [Re: elmor353] #2593100
12/17/18 12:15 PM
12/17/18 12:15 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Getting 400 HP From A Smogger 440 [Re: elmor353] #2593103
12/17/18 12:19 PM
12/17/18 12:19 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Edelbrock E-street heads, 0.020" head gasket, mild cam around 220+ duration @ 0.050, >0.470" lift.
Re: Getting 400 HP From A Smogger 440 [Re: elmor353] #2593138
12/17/18 01:59 PM
12/17/18 01:59 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Have you seen this article from FABO...
https://www.forabodiesonly.com/mopar/threads/dyno-a-7-5-1-400-sure-why-not.293381/
If they can get 400 hp from a low-compression 400 that easily, you can certainly do it with 10% more cubes smile
Re: Getting 400 HP From A Smogger 440 [Re: elmor353] #2593173
12/17/18 03:18 PM
12/17/18 03:18 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
How about 449HP and 472 tq from a smogger..... read this
https://www.forabodiesonly.com/mopar/threads/dyno-testing-a-stock-1972-440.249866/
Re: Getting 400 HP From A Smogger 440 [Re: elmor353] #2593196
12/17/18 03:39 PM
12/17/18 03:39 PM
I would try and sell both sets of your other iron heads and use that money to buy a set of the 440 source 80.CC aluminum heads that will out flow your heads and raise the compression more also work up twocents
Re: Getting 400 HP From A Smogger 440 [Re: elmor353] #2593396
12/17/18 10:14 PM
12/17/18 10:14 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The super charger kits will certainly get you to 400+ HP. But they are $2,800 plus a blow-thru carb. And even that doesn't include any costs associated with the ignition curve or meth injection. So, it could easily get to $4,000. Or close to.
New aluminum heads and a cam kit would seem to be the logical choice when it comes to bang for the buck.
Master, again and still
Re: Getting 400 HP From A Smogger 440 [Re: elmor353] #2593403
12/17/18 10:23 PM
12/17/18 10:23 PM
Kirkland, Washington
Pacnorthcuda Offline
If you're really trying to keep this low buck (as in no new heads), then camshaft, mill and port the heads and intake a bit, and you should be there.
Re: Getting 400 HP From A Smogger 440 [Re: 451Mopar] #2593615
12/18/18 05:54 AM
12/18/18 05:54 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I posted this above because we were going to go this route with Dans '77 440 before we found the cast crank was > 0.004" clearance and the journals were gouged pretty good. Decided to just go stroker kit. Alot more $$$$, but alot more power too.
Re: Getting 400 HP From A Smogger 440 [Re: elmor353] #2593625
12/18/18 06:59 AM
12/18/18 06:59 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I stuck some Edelbrock heads and a .660 roller in a "smogger" 400 and I love it! Runs real good!
Re: Getting 400 HP From A Smogger 440 [Re: elmor353] #2593979
12/18/18 10:01 PM
12/18/18 10:01 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
cheaper to change the pistons
5549 post on old board
Re: Getting 400 HP From A Smogger 440 [Re: 05dakota] #2593989
12/18/18 10:31 PM
12/18/18 10:31 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Cheaper than what?
Re: Getting 400 HP From A Smogger 440 [Re: elmor353] #2594077
12/19/18 01:51 AM
12/19/18 01:51 AM
Canada
CrAzYMoPaRGuY Offline
Canada
I agree. Read the article. Crazy
CrAzYMoPaRGuY
Re: Getting 400 HP From A Smogger 440 [Re: CrAzYMoPaRGuY] #2595649
12/22/18 10:52 PM
12/22/18 10:52 PM
E
elmor353 Offline OP
elmor353  Offline OP
E
I was very impressed with the article and the numbers they pulled from the low compression engine. I have a set of 516 heads with big valves in them and was wondering if the MP porting templates are still available? My porting won't be on par with theirs, but I would love to try and duplicate that engine, only using the larger of the Summit cams and a Performer RPM intake instead of the 509 and single plane intake. As an after thought, I have a set of 906 heads set up with Crane springs. I don't think I will give up much compression using them with .020 gaskets. Perhaps with minimal port work they would be a better alternative?
Re: Getting 400 HP From A Smogger 440 [Re: elmor353] #2595652
12/22/18 11:22 PM
12/22/18 11:22 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The 906’s would be better.
IMO, there are better choices for what you’re doing than the summit cam.
Something like a Comp xe268, xe274, PP280, 280h.
Re: Getting 400 HP From A Smogger 440 [Re: elmor353] #2595663
12/23/18 12:21 AM
12/23/18 12:21 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I don't think so, but I got them and they are not worthly. Is just about use the logic making the work... I'm posting them if you want ( with an scale to print them correctly )
( I don't know where I left my templates... they must be... somewhere around! I can't tell )
Re: Getting 400 HP From A Smogger 440 [Re: elmor353] #2595736
12/23/18 11:37 AM
12/23/18 11:37 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
More complete porting templates, had to zip it to get it under the 2MB limit.
Includes B/RB/LA/Magnum templates.
Not mine and I forget where I got it from.
Try this one, it should work now.
Attached PDF document
Re: Getting 400 HP From A Smogger 440 [Re: elmor353] #2595755
12/23/18 01:03 PM
12/23/18 01:03 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
great!!! but is not working LOL. It seems there is some damage to the PDF file trying to extract it.
Or maybe some ZIP problem trying to extract it with Winrar?
Re: Getting 400 HP From A Smogger 440 [Re: NachoRT74] #2595760
12/23/18 01:14 PM
12/23/18 01:14 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Interesting, I can extract the zip file I made, but not the one I downloaded from Moparts, should be the same. Odd.
Re: Getting 400 HP From A Smogger 440 [Re: elmor353] #2595763
12/23/18 01:18 PM
12/23/18 01:18 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That's been done a time or two. Here's a circa 1979/1980 package. You won't have any problems, but if you do chase compression much at all you'll find it really wakes it up.
Rich H.
Esse Quam Videri
