Re: Getting 400 HP From A Smogger 440
[Re: elmor353]
#2593396
12/17/18 10:14 PM
12/17/18 10:14 PM
Posts: 12,162 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The super charger kits will certainly get you to 400+ HP. But they are $2,800 plus a blow-thru carb. And even that doesn't include any costs associated with the ignition curve or meth injection. So, it could easily get to $4,000. Or close to.
New aluminum heads and a cam kit would seem to be the logical choice when it comes to bang for the buck.
Master, again and still
[Re: 451Mopar]
#2593615
12/18/18 05:54 AM
12/18/18 05:54 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Edelbrock E-street heads, 0.020" head gasket, mild cam around 220+ duration @ 0.050, >0.470" lift. I posted this above because we were going to go this route with Dans '77 440 before we found the cast crank was > 0.004" clearance and the journals were gouged pretty good. Decided to just go stroker kit. Alot more $$$$, but alot more power too.
[Re: elmor353]
#2593979
12/18/18 10:01 PM
12/18/18 10:01 PM
Posts: 17,861 albany ny
05dakota
albany ny
cheaper to change the pistons
5549 post on old board
[Re: 05dakota]
#2593989
12/18/18 10:31 PM
12/18/18 10:31 PM
Posts: 1,459 oklahoma
forphorty
oklahoma
cheaper to change the pistons Cheaper than what?
[Re: elmor353]
#2594077
12/19/18 01:51 AM
12/19/18 01:51 AM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
I agree. Read the article. Crazy
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2595649
12/22/18 10:52 PM
12/22/18 10:52 PM
Posts: 870 Keizer, Oregon U.S.A.
elmor353
I was very impressed with the article and the numbers they pulled from the low compression engine. I have a set of 516 heads with big valves in them and was wondering if the MP porting templates are still available? My porting won't be on par with theirs, but I would love to try and duplicate that engine, only using the larger of the Summit cams and a Performer RPM intake instead of the 509 and single plane intake. As an after thought, I have a set of 906 heads set up with Crane springs. I don't think I will give up much compression using them with .020 gaskets. Perhaps with minimal port work they would be a better alternative?
[Re: elmor353]
#2595652
12/22/18 11:22 PM
12/22/18 11:22 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The 906’s would be better.
IMO, there are better choices for what you’re doing than the summit cam.
Something like a Comp xe268, xe274, PP280, 280h.
[Re: elmor353]
#2595663
12/23/18 12:21 AM
12/23/18 12:21 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
and was wondering if the MP porting templates are still available? I don't think so, but I got them and they are not worthly. Is just about use the logic making the work... I'm posting them if you want ( with an scale to print them correctly ) ( I don't know where I left my templates... they must be... somewhere around! I can't tell )
[Re: elmor353]
#2595736
12/23/18 11:37 AM
12/23/18 11:37 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
More complete porting templates, had to zip it to get it under the 2MB limit.
Includes B/RB/LA/Magnum templates.
Not mine and I forget where I got it from.
Try this one, it should work now.
[Re: elmor353]
#2595755
12/23/18 01:03 PM
12/23/18 01:03 PM
NachoRT74
Valencia, España
great!!! but is not working LOL. It seems there is some damage to the PDF file trying to extract it.
Or maybe some ZIP problem trying to extract it with Winrar?
[Re: NachoRT74]
#2595760
12/23/18 01:14 PM
12/23/18 01:14 PM
Supercuda
About to go away
About to go away
up yours
great!!! but is not working LOL. It seems there is some damage to the PDF file trying to extract it Interesting, I can extract the zip file I made, but not the one I downloaded from Moparts, should be the same. Odd.
[Re: elmor353]
#2595763
12/23/18 01:18 PM
12/23/18 01:18 PM
Posts: 17,876 S.E. Michigan
ZIPPY
S.E. Michigan
That's been done a time or two. Here's a circa 1979/1980 package. You won't have any problems, but if you do chase compression much at all you'll find it really wakes it up.
Rich H.
Esse Quam Videri
