Re: Rallye Dash vs Standard Dash - Dash differences
[Re: MONC]
#2592566
12/15/18 11:05 PM
12/15/18 11:05 PM
Posts: 3,656 The Historic Hudson Valley
MONC
I remember someone telling me when they wanted a Rallye dash instead of the standard dash it wasn't just a swap out. Some kind of support or other bracket is required.
Mopar Or No Car
[Re: MONC]
#2592572
12/15/18 11:24 PM
12/15/18 11:24 PM
Posts: 5,106 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
The Last one I did about 15 years ago it was just a bolt in. These was a small difference in the wiring.
1971 HEMI E BODY REGISTRY
Re: Rallye Dash vs Standard Dash -E BODY Dash differences
[Re: MONC]
#2592644
12/16/18 03:26 AM
12/16/18 03:26 AM
Posts: 18,157 Mass
DAYCLONA
Mass
From my understanding there is a difference between how the Rallye Dash and Standard dash mount into the dashboard. I think it was some kind of support bracket for the Rallye dash or something. Can someone clarify, and if possible provide a picture with a point of reference?
Thanks No bracket/support, the swap over to rallye is a bolt in, however to convert from standard to rallye you need the pod/gauge cluster, the rallye switch panel, and the rallye heater/HVAC control panel, you'll need the 4 light under dash light bar, although you could get by with the 3 light, some alteration of the harness is needed for connectors, tach wire/clock, you'll need to change the oil sender unit on the engine to the gauge style, if your doing a 70 Challenger, you'll need a 70-74 Cuda/71-74 Challenger radio bezel as well, as the 70 Challenger standard dash bezel is one year only and not compatible cosmetic wise to the rallye dash pebble/wrinkle grain grain finish... Mike
[Re: DAYCLONA]
#2600916
01/03/19 01:45 PM
01/03/19 01:45 PM
Posts: 3,358 Berwyn, IL
challenger70
Berwyn, IL
Hard to tell what you have by that pic, lol. But yes if it is 4 and correct for an e-body it is a rally dash light bar. As mentioned below there is a LOT (LOT!!!) to change and do it correctly, also not mentioned is the wiper motor, wiper arm, wiper switch, correct wiring harness (can get by without) and wiper linkage under the cowl. Having gathered all the correct parts and restoring them I can say it is probably cheaper to buy a real r/t or 'cuda from the get go. I am probably 5-6k into the parts/resto costs. Having a '70 Challenger it's been extra fun getting all the specific parts for them. I did not realize the oil sending unit was different, thanks for that tidbit!
Mike
Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE
[Re: MONC]
#2601468
01/04/19 02:14 PM
01/04/19 02:14 PM
MONC
I'll do some further checking on the bezel, see what I find.
Thought the pic was clear enough showing 4 lights on with a Standard Dash.
Mopar Or No Car
[Re: MONC]
#2601504
01/04/19 03:09 PM
01/04/19 03:09 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
not to help on the thread, but... being E bodies so nice cars and the cluster ligting makes them look so ugly!!! what the hell were they thinking ? ( sure is a blurred pic, but still )
[Re: MONC]
#2601531
01/04/19 03:56 PM
01/04/19 03:56 PM
NachoRT74
Valencia, España
still with LEDs, looks awfull LOL. Sorry is just about taste maybe. ok, I'm done
[Re: MONC]
#2602452
01/06/19 03:31 PM
01/06/19 03:31 PM
MONC
Agreed not the best set up, but easier to replace bulbs on the E-bodies than on the B-bodies behind the dash.
So here are 2 pictures. First one is the Standard dash with the bezel on DS of steering wheel. Second is a pic of rallye dash with the bezel on the DS of steering wheel for comparison.
So my question is , is the first bezel for standard dash or a rallye dash?
Mopar Or No Car
