Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE #2592496
12/15/18 07:59 PM
12/15/18 07:59 PM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
From my understanding there is a difference between how the Rallye Dash and Standard dash mount into the dashboard.
I think it was some kind of support bracket for the Rallye dash or something.
Can someone clarify, and if possible provide a picture with a point of reference?
Re: Rallye Dash vs Standard Dash - Dash differences [Re: MONC] #2592508
12/15/18 08:33 PM
12/15/18 08:33 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
For what car?
Re: Rallye Dash vs Standard Dash - Dash differences [Re: MONC] #2592522
12/15/18 08:59 PM
12/15/18 08:59 PM
MONC Offline OP
MONC  Offline OP
Duh, that would be helpful wouldn't it?
For a 70 E Body
Mopar
Or
No
Car
Re: Rallye Dash vs Standard Dash - Dash differences [Re: MONC] #2592556
12/15/18 10:40 PM
12/15/18 10:40 PM
BDW Offline
BDW  Offline
Never seen any difference or support bracket.
Re: Rallye Dash vs Standard Dash - Dash differences [Re: MONC] #2592566
12/15/18 11:05 PM
12/15/18 11:05 PM
MONC Offline OP
MONC  Offline OP
I remember someone telling me when they wanted a Rallye dash instead of the standard dash it wasn't just a swap out. Some kind of support or other bracket is required.
Mopar
Or
No
Car
Re: Rallye Dash vs Standard Dash - Dash differences [Re: MONC] #2592572
12/15/18 11:24 PM
12/15/18 11:24 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
The Last one I did about 15 years ago it was just a bolt in. These was a small difference in the wiring.
1971 HEMI E BODY REGISTRY
Re: Rallye Dash vs Standard Dash - Dash differences [Re: MONC] #2592577
12/15/18 11:37 PM
12/15/18 11:37 PM
Candler,NC / Myrtle Beach, SC
JDMopar Online content
JDMopar  Online Content
There's no difference in the dash frame. Non rallye to rallye dash conversion is a direct bolt in except for the wiring. The light bar is different. A standard dash has 3 bulbs, and a rallye dash has 4 bulbs. Be sure to put ALL of the screws in the switch panel. One of them provides the ground for the switch panel to the dash frame, and if you leave that particular screw out it will drive you nuts trying to figure out why the lights and wipers won't work right!
Re: Rallye Dash vs Standard Dash - Dash differences [Re: MONC] #2592580
12/15/18 11:52 PM
12/15/18 11:52 PM
Maryland
MoparMike1974 Offline
Maryland
Its probably the light bar your talking about. The rallye bar has one extra lamp on it.
There are differences in the instrument cluster by year. I think 70 used a cable to connect the knob to the clock and later the knob came straight out through the lens.
Re: Rallye Dash vs Standard Dash -E BODY Dash differences [Re: MONC] #2592644
12/16/18 03:26 AM
12/16/18 03:26 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
No bracket/support, the swap over to rallye is a bolt in, however to convert from standard to rallye you need the pod/gauge cluster, the rallye switch panel, and the rallye heater/HVAC control panel, you'll need the 4 light under dash light bar, although you could get by with the 3 light, some alteration of the harness is needed for connectors, tach wire/clock, you'll need to change the oil sender unit on the engine to the gauge style, if your doing a 70 Challenger, you'll need a 70-74 Cuda/71-74 Challenger radio bezel as well, as the 70 Challenger standard dash bezel is one year only and not compatible cosmetic wise to the rallye dash pebble/wrinkle grain grain finish...
Mike
Re: Rallye Dash vs Standard Dash -E BODY Dash differences [Re: DAYCLONA] #2592666
12/16/18 04:44 AM
12/16/18 04:44 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
there are 4-different E-body "light bars"
3-light bars are
'70 Challenger STANDARD # 2984 166
'70 Barracuda & '71-'74 E-body STANDARD # 2984 126
4-light bars are
'70 Challenger RALLYE # 2984 081
'70 Barracuda & '71-'74 E-body RALLYE # 2984 187
8-41-41 of a Parts Catalog
a bunch of '70 Challenger "stuff" is '70 Challenger ONLY
Re: Rallye Dash vs Standard Dash -E BODY Dash differences [Re: MONC] #2592865
12/16/18 05:41 PM
12/16/18 05:41 PM
MONC Offline OP
MONC  Offline OP
Dang this is a lot of info.
Great info, but I gotta go through it more.
Thanks for the feedback
Mopar
Or
No
Car
Re: Rallye Dash vs Standard Dash -E BODY Dash differences [Re: MONC] #2600900
01/03/19 01:20 PM
01/03/19 01:20 PM
MONC Offline OP
MONC  Offline OP
So I checked and I have 4 lights but a standard dash.
Does that mean it was likely an original Rallye Gauge car?
Re: Rallye Dash vs Standard Dash -E BODY Dash differences [Re: DAYCLONA] #2600916
01/03/19 01:45 PM
01/03/19 01:45 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
Hard to tell what you have by that pic, lol. But yes if it is 4 and correct for an e-body it is a rally dash light bar.
As mentioned below there is a LOT (LOT!!!) to change and do it correctly, also not mentioned is the wiper motor, wiper arm, wiper switch, correct wiring harness (can get by without) and wiper linkage under the cowl.
Having gathered all the correct parts and restoring them I can say it is probably cheaper to buy a real r/t or 'cuda from the get go. eek I am probably 5-6k into the parts/resto costs. Having a '70 Challenger it's been extra fun getting all the specific parts for them.
I did not realize the oil sending unit was different, thanks for that tidbit!
Mike
Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE [Re: MONC] #2601082
01/03/19 07:21 PM
01/03/19 07:21 PM
central il.
second 70 Offline
second 70  Offline
central il.
The dash is a direct bolt in. Now depending on how OEM you want it you can do as little as add a wire for clock and tach and a new oil sender.
But if you want OEM the heater bezel isn’t the same. There will be a curved space on the left side of steering column that will be open. The rallye heater bezel is longer and covers the gap. I laughed a couple of weeks ago on graveyard cars He was showing off a inviolet Cuda pointing out it came with a rallye dash and you could see the gap clearly showing it was not original.
I didn’t know that when I swapped one out and instead of trying to find one and swap it out I came up with a quick fix of making a bezel cover to hide the gap. The one picture is the first one I made is painted cardboard that I made as a joke but after nobody could tell when it was installed I made the one on the car out of thin metal and painted it. If you look close you’ll see where’s it at on the raised edge of the heater bezel. It’s held on by the screw on the top right. The cardboard one was just taped on.
Mike.
Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE [Re: MONC] #2601468
01/04/19 02:14 PM
01/04/19 02:14 PM
MONC Offline OP
MONC  Offline OP
I'll do some further checking on the bezel, see what I find.
Thought the pic was clear enough showing 4 lights on with a Standard Dash.
Mopar
Or
No
Car
Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE [Re: MONC] #2601504
01/04/19 03:09 PM
01/04/19 03:09 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
not to help on the thread, but... being E bodies so nice cars and the cluster ligting makes them look so ugly!!!
what the hell were they thinking ?
( sure is a blurred pic, but still )
Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE [Re: MONC] #2601519
01/04/19 03:44 PM
01/04/19 03:44 PM
BDW Offline
BDW  Offline
Get LEDs
Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE [Re: MONC] #2601531
01/04/19 03:56 PM
01/04/19 03:56 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
still with LEDs, looks awfull LOL. Sorry is just about taste maybe.
ok, I'm done wink
Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE [Re: MONC] #2602452
01/06/19 03:31 PM
01/06/19 03:31 PM
MONC Offline OP
MONC  Offline OP
Agreed not the best set up, but easier to replace bulbs on the E-bodies than on the B-bodies behind the dash.
So here are 2 pictures.
First one is the Standard dash with the bezel on DS of steering wheel.
Second is a pic of rallye dash with the bezel on the DS of steering wheel for comparison.
So my question is , is the first bezel for standard dash or a rallye dash?
Mopar
Or
No
Car
Re: Rallye Dash vs Standard Dash -E BODY Dash diff. - UPDATE [Re: MONC] #2602454
01/06/19 03:33 PM
01/06/19 03:33 PM
MONC Offline OP
MONC  Offline OP
Standard Dash bezel
Mopar
Or
No
Car
