ring and pinion woes... #259229
03/19/09 04:46 PM
03/19/09 04:46 PM
Northern Indiana
capac Offline OP
capac  Offline OP
Northern Indiana
Installed new ring and pinion last weekend, and the wear pattern is bad....
How can I remove the bearing off the pinion? I need to shim the bearing.
This is a 8.25" rear.
'64 390 Valiant Signet Convertable (WIP...)
Re: ring and pinion woes... [Re: capac] #259230
03/19/09 04:50 PM
03/19/09 04:50 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Press the pinion out of the bearing. Take it to a shop if you don't have a press.
Re: ring and pinion woes... [Re: In_The_Pink] #259231
03/19/09 06:25 PM
03/19/09 06:25 PM
Northern Indiana
capac Offline OP
capac  Offline OP
Northern Indiana
I have a press at work but I have no idea how to get it off...
Re: ring and pinion woes... [Re: capac] #259232
03/19/09 06:28 PM
03/19/09 06:28 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
You need one of these.
Re: ring and pinion woes... [Re: John_Kunkel] #259233
03/19/09 06:36 PM
03/19/09 06:36 PM
Northern Indiana
capac Offline OP
capac  Offline OP
Northern Indiana
There is absolutely no room between the bearing race and the back of the pinion. Unless I need to destroy my new bearing to get to the inside lip...
Re: ring and pinion woes... [Re: capac] #259234
03/19/09 06:41 PM
03/19/09 06:41 PM
Mass
dgc333 Offline
dgc333  Offline
Mass
The shim on an 8.25 goes between the race and the case. There are reliefs in the case to tap the race out so there is no need to get the bearing off the pinion.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
Re: ring and pinion woes... [Re: dgc333] #259235
03/19/09 07:00 PM
03/19/09 07:00 PM
Northern Indiana
capac Offline OP
capac  Offline OP
Northern Indiana
Wouldn't the shims have to go behind the 'bigger' race? If so, the shims in the kit were way too small...
Re: ring and pinion woes... [Re: dgc333] #259236
03/19/09 08:05 PM
03/19/09 08:05 PM
Northern Indiana
capac Offline OP
capac  Offline OP
Northern Indiana
OK, everywhere I look I see shims being placed on the pinion itself. I would much prefer punching out the race and doing it that way but I'm kind of confused based on the size of the shims...
Re: ring and pinion woes... [Re: capac] #259237
03/19/09 08:28 PM
03/19/09 08:28 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
That is correct. There is a special tool used to remove the pinion bearing pictured in the factory service manual, looking much like the one John posted above.
Re: ring and pinion woes... [Re: In_The_Pink] #259238
03/19/09 08:40 PM
03/19/09 08:40 PM
Northern Indiana
capac Offline OP
capac  Offline OP
Northern Indiana
Where can I buy said tool?
Re: ring and pinion woes... [Re: capac] #259239
03/19/09 09:26 PM
03/19/09 09:26 PM
florida
74fldart Offline
74fldart  Offline
florida
ive seen those on ebay, search for bearing seperator
Re: ring and pinion woes... [Re: capac] #259240
03/19/09 09:58 PM
03/19/09 09:58 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
If you have an old bearing, just hone out the ID a little to make it a slip fit on the pinion. When you get the shim setup/contact pattern correct just replace it with the pres fit/new bearing. Saves you from potentially damaging new parts..
Re: ring and pinion woes... [Re: capac] #259241
03/20/09 08:11 AM
03/20/09 08:11 AM
Mass
dgc333 Offline
dgc333  Offline
Mass
When I rebuilt my 8.25 there were no shims between the bearing and the pinion and there were (3) between the race and the case. The master kit I got also had shims for the pinion. I lucked out and two of the ones behind the race got mine pinion where it needed to be so I never had to go looking for the larger shims.
BTW, I mocked up mine with some gauge blocks and a drop indicator to set it for the depth engraved onto the end of the new pinion. I was within 0.002" and when I put it together the pattern was perfect. Also, a lot of pinions will have another number engraved onto the bottom like +.004 or -.002. If the existing one has a similar number you take the difference and adjust the shim pack by that much and you will be where you need to be.
Re: ring and pinion woes... [Re: capac] #259242
03/20/09 08:18 AM
03/20/09 08:18 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You are going to destroy the bearing even with that plate , buy a new bearing . I have honed out bearings with a flapper wheel so I could make a test bearing , you'll need about 5 of those wheels to do the job, do it if you think you'll be doing this more than once.
Or you can put the pinion in a drill press or a lathe and polish the shaft where the bearing goes till you can just get the bearing to slide on and get it off by hand , I saw that in a tape I got from Richmond on how to set up rear gears .
Re: ring and pinion woes... [Re: JohnRR] #259243
03/21/09 11:19 AM
03/21/09 11:19 AM
Northern Indiana
capac Offline OP
capac  Offline OP
Northern Indiana
OK. Took pinion out and had a local shop pull both bearings on the old pinion and new. Then I made a 'slip-on' bearing out of the old one, good thing I did too. It took 4 times to get a pattern that I liked.
Now a new problem has developed: I can't get the crush sleeve to crush! I am using a brand new CP Earthquake impact (625 ft lbs). There is about 20-30 thousanths(sp) of in and out play... so I'm guesing that the sleeve isn't crushing.
Any ideas/tricks?
Re: ring and pinion woes... [Re: capac] #259244
03/21/09 03:43 PM
03/21/09 03:43 PM
Northern Indiana
capac Offline OP
capac  Offline OP
Northern Indiana
Anyone?
Re: ring and pinion woes... [Re: capac] #259245
03/21/09 04:08 PM
03/21/09 04:08 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Who told you to use an air impact wrench to tighten the pinion nut? What instructions are you reading?
The FSM tells you to torque the pinion nut to 170 foot pounds of torque and then check the preload. If there is not enough preload, keep tightening until you reach proper preload. If you exceed the proper preload, you will need to replace the crush sleeve and start over.
Re: ring and pinion woes... [Re: capac] #259246
03/21/09 04:10 PM
03/21/09 04:10 PM
Wisconsin USA
Wisconsin USA
Try a torque wrench, don't think an impact will do it.
Re: ring and pinion woes... [Re: capac] #259247
03/21/09 04:13 PM
03/21/09 04:13 PM
Rio Linda, CA
Rio Linda, CA
It's a bad idea to use an impact on a crush sleeve pinion nut, too easy to overtorque and ruin the crush sleeve. Just use a cheater bar and take the nut down slowly.
Re: ring and pinion woes... [Re: John_Kunkel] #259248
03/21/09 04:26 PM
03/21/09 04:26 PM
Snoopy Offline
Snoopy  Offline
Did you use the correct belleville washer under the nut and is it correctly positioned, convex side of washer up?
From the 70 FSM
