Rust #2592041
12/14/18 08:34 PM
12/14/18 08:34 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
I'm noticing some rust on the bottom of my Neon, nothing serious, I just would like to nip it in the bud. I was thinking of some rust converter and then brush on some Rustoleum. What do you all think is a good converter? Evaporust, or some other brand.
Re: Rust [Re: 71birdJ68] #2592050
12/14/18 08:47 PM
12/14/18 08:47 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I would grind/sand/cut until you have actual clean metal. THEN rust proof and paint. Body rot is always worse than you think it is. work
My '93 BMW had about a 2" area of "not too serious" rust visible underneath, at the driver's outer footwell body plug. By the time I finished removing rust, here is the result...
Re: Rust [Re: 71birdJ68] #2592051
12/14/18 08:47 PM
12/14/18 08:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Ospho available at Ace hardware
Re: Rust [Re: stumpy] #2592278
12/15/18 12:47 PM
12/15/18 12:47 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
iagree up
Re: Rust [Re: bonefish] #2592290
12/15/18 01:10 PM
12/15/18 01:10 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
If it is surface rust, you can treat it.
It will return.
Thing is, rust rarely is only skin deep.
If it is inside the panels, there really is nothing you can do besides replace the sheet metal.
It's simply part of the plan to sell more cars.
I have mechanical Aptitude.
I can screw up anything.
Re: Rust [Re: bboogieart] #2592350
12/15/18 02:51 PM
12/15/18 02:51 PM
Morristown Tn.
Morristown Tn.
I can't knok my Neon much, it was built in 94 and has 498,000 miles on it.
Re: Rust [Re: 71birdJ68] #2592363
12/15/18 03:07 PM
12/15/18 03:07 PM
moparx Offline
moparx  Offline
i would file that car under the lemon law with your dealer ! flame stirthepot laugh2
beer
Re: Rust [Re: 71birdJ68] #2592537
12/15/18 09:28 PM
12/15/18 09:28 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Remove the loose stuff and spray bomb with VHT. Top coat with a wax-oil type product and touch up as needed.
"rust converters" are a myth IMO. It does look nice until a year later and you notice the cancer has erupted right back and gained more territory.
The cars that are all slimy and nasty underneath whether intentional or from a leaking engine tend to be less rusty and easier to work on.
