Saw the new SB Trick Flow heads... #2588933
12/08/18 03:34 AM
12/08/18 03:34 AM
The Great State of PA
tabletop390 Offline OP
And meh. Wasn’t too impressed with them. Comparing them damn near side by side with the ProMaxx Shockers they almost seemed identical. The Trick Flow heads are going to be released in March with the same price point as the ProMaxx. Also being released from Trick Flow is a new SB intake manifold. I went to PRI to give them a good look and also got the flow info and assembled valve sizes, etc.
Now the thing that really got me going were the new FST carbs and the electronic jet kit they’re about to offer. Basically turns the carb into a fuel injection/carb hybrid. Can adjust the jetting on your carb with a Bluetooth device and can go up and down 10 jet sizes.
Re: Saw the new SB Trick Flow heads... [Re: tabletop390] #2588949
12/08/18 04:21 AM
12/08/18 04:21 AM
Melbourne , Australia
LA360 Online boogie
LA360  Online Boogie
I will have to go by the stand tomorrow
Alan Jones
Re: Saw the new SB Trick Flow heads... [Re: tabletop390] #2589034
12/08/18 03:01 PM
12/08/18 03:01 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
There is only so much that can be done within the "stockish" architechture especialy considering the boneheaded crowd that us moparowners are that complain if the part is not 100% compatible with stuck junk everwhere.
Re: Saw the new SB Trick Flow heads... [Re: 1Fast340] #2589067
12/08/18 04:46 PM
12/08/18 04:46 PM
I agree. I would have at least like to have seen an attempt dual exhaust manifold mounting since the exhaust port is more of a D shape like the Indy’s. In all honesty it’s beginning to look like everyone is getting the same heads cut on the same machine and stamping their own name on the heads.
Re: Saw the new SB Trick Flow heads... [Re: tabletop390] #2589171
12/08/18 10:51 PM
12/08/18 10:51 PM
Washington
madscientist Offline
Washington
I'm more interested in the intake manifold than those heads.
Re: Saw the new SB Trick Flow heads... [Re: tabletop390] #2589245
12/09/18 02:26 AM
12/09/18 02:26 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
I looked at the heads today also they look nothing at all like a promaxx or edlebrock head if I could post some pictures of the heads I would I don’t understand why moparts will not let a I phone load pictures like Facebook and a body’s only
Re: Saw the new SB Trick Flow heads... [Re: scottb] #2589267
12/09/18 06:34 AM
12/09/18 06:34 AM
Washington
skrews Offline
skrews  Offline
Washington
Agreed. The TFs are much improved over the Edelbrock and all of the China Edelbrock knock off castings, especially the chamber.
Re: Saw the new SB Trick Flow heads... [Re: madscientist] #2589268
12/09/18 06:36 AM
12/09/18 06:36 AM
Washington
skrews Offline
skrews  Offline
Washington
Yep. Looks like an M1 with the hermaphrodite spread/square bore flange fixed.
Re: Saw the new SB Trick Flow heads... [Re: skrews] #2590034
12/10/18 08:29 PM
12/10/18 08:29 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
I saw the SB TF heads and talked to their rep at the PRI show... He said they will be released approximately in May 2019 as there have been casting problems getting fixed. The exhaust ports were square and small ... instead of the more common factory design... puzzles me for exhaust gasket sealing.
Re: Saw the new SB Trick Flow heads... [Re: tabletop390] #2590590
12/11/18 09:52 PM
12/11/18 09:52 PM
Fort Collins, CO
K
khuebner250 Offline
khuebner250  Offline
K
Fort Collins, CO
I keep seeing foundry issues. Is this effecting other TF products?
Re: Saw the new SB Trick Flow heads... [Re: skrews] #2590604
12/11/18 10:33 PM
12/11/18 10:33 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Looks more like a strip dominator to me
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Saw the new SB Trick Flow heads... [Re: khuebner250] #2590618
12/11/18 11:10 PM
12/11/18 11:10 PM
Texas
RustyM Offline
RustyM  Offline
Texas
all the Trick Flow products we have purchased have been very well finished- no issues at all.
My guess is what your seeing is the reason that haven't been released yet.
just my thoughts.
Re: Saw the new SB Trick Flow heads... [Re: tabletop390] #2590619
12/11/18 11:13 PM
12/11/18 11:13 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
They will be great bolt on heads. Cant wait to buy a set. They look super nice
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Saw the new SB Trick Flow heads... [Re: khuebner250] #2590624
12/11/18 11:24 PM
12/11/18 11:24 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I was at PRI also and the tech told me they had casting's in from the foundry and are going to cut them up and check for casting problems before they give the foundry the go ahead for production, said they had made a few minor changes along the way, I thought they were a very nice looking head. up
Re: Saw the new SB Trick Flow heads... [Re: B3422W5] #2590645
12/12/18 12:24 AM
12/12/18 12:24 AM
Washington
Washington
SD and M1 are essentially the same.
