Re: Saw the new SB Trick Flow heads...
[Re: tabletop390]
#2589171
12/08/18 10:51 PM
12/08/18 10:51 PM
Posts: 4,457 Washington
madscientist
Washington
I'm more interested in the intake manifold than those heads.
[Re: scottb]
#2589267
12/09/18 06:34 AM
12/09/18 06:34 AM
Posts: 425 Washington
skrews
Washington
I looked at the heads today also they look nothing at all like a promaxx or edlebrock head if I could post some pictures of the heads I would I don’t understand why moparts will not let a I phone load pictures like Facebook and a body’s only Agreed. The TFs are much improved over the Edelbrock and all of the China Edelbrock knock off castings, especially the chamber.
[Re: madscientist]
#2589268
12/09/18 06:36 AM
12/09/18 06:36 AM
skrews
Washington
I'm more interested in the intake manifold than those heads. Yep. Looks like an M1 with the hermaphrodite spread/square bore flange fixed.
[Re: skrews]
#2590034
12/10/18 08:29 PM
12/10/18 08:29 PM
Posts: 1,440 NW Chicago suburban area
Mopar Mitch
I saw the SB TF heads and talked to their rep at the PRI show... He said they will be released approximately in May 2019 as there have been casting problems getting fixed. The exhaust ports were square and small ... instead of the more common factory design... puzzles me for exhaust gasket sealing.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: skrews]
#2590604
12/11/18 10:33 PM
12/11/18 10:33 PM
Posts: 11,701 Portage,michigan
B3422W5
Portage,michigan
I'm more interested in the intake manifold than those heads. Yep. Looks like an M1 with the hermaphrodite spread/square bore flange fixed. Looks more like a strip dominator to me
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: tabletop390]
#2590619
12/11/18 11:13 PM
12/11/18 11:13 PM
B3422W5
Portage,michigan
They will be great bolt on heads. Cant wait to buy a set. They look super nice
[Re: khuebner250]
#2590624
12/11/18 11:24 PM
12/11/18 11:24 PM
dartman366
Mt. Vernon, Ohio
I keep seeing foundry issues. Is this effecting other TF products? I was at PRI also and the tech told me they had casting's in from the foundry and are going to cut them up and check for casting problems before they give the foundry the go ahead for production, said they had made a few minor changes along the way, I thought they were a very nice looking head.
[Re: B3422W5]
#2590645
12/12/18 12:24 AM
12/12/18 12:24 AM
madscientist
Washington
I'm more interested in the intake manifold than those heads. Yep. Looks like an M1 with the hermaphrodite spread/square bore flange fixed. Looks more like a strip dominator to me SD and M1 are essentially the same.
