Best 440 intake w/dominator carb #2589860
12/10/18 03:18 PM
12/10/18 03:18 PM
Chicago land, IL
dafixr Offline OP
dafixr  Offline OP
Chicago land, IL
What is the best intake for a 499 big block stroker
race only with a 1150 dominator
or can we use the adapator to use our 4150 manifold now
Re: Best 440 intake w/dominator carb [Re: dafixr] #2589867
12/10/18 03:24 PM
12/10/18 03:24 PM
It depends on which size ports on which intake will work the best, I have change the bolt pattern size to fit Dominator carbs. on more than one intake, the last one was a Indy dual 4500 tunnel ram that I wanted to run a set of 4150 type throttle body with them in line for the linkage shruggy work
On your deal make sure that the throttle blades will clear the intake manifold once you mount the carb by changing the bolt pattern scope
Re: Best 440 intake w/dominator carb [Re: dafixr] #2589868
12/10/18 03:26 PM
12/10/18 03:26 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
What head and rpm range are you looking for?
Re: Best 440 intake w/dominator carb [Re: dafixr] #2589874
12/10/18 03:30 PM
12/10/18 03:30 PM
AndyF Offline
AndyF  Offline
Not sure what you mean by best so you'll have to clarify that a bit. I assume you mean the best that you can afford so that most likely means something like a Super Victor or Indy 440-3. Personally I like the Super Victor better than the Indy stuff.
If you really want a good intake then you need to send it to someone like Wilson Manifolds for their porting magic. Once you do that then you'll have a good intake.
Re: Best 440 intake w/dominator carb [Re: dafixr] #2589878
12/10/18 03:37 PM
12/10/18 03:37 PM
tboomer Online work
tboomer  Online Work
I have the big Indy on my 512 RB with an 1150 Dominator. I have Victor Max wedge size ports and all intake work was done by Roger Lechtenberg. You may want to do a google search on that name! laugh2
Re: Best 440 intake w/dominator carb [Re: AndyF] #2589885
12/10/18 03:52 PM
12/10/18 03:52 PM
Chicago land, IL
dafixr Offline OP
dafixr  Offline OP
Chicago land, IL
the intake is a victor and eledbrock alum heads that we have on it now not sure which heads
carb is 950 quick fuel
we are planning to change cam, convertor and carb for next season.
I will check to nite.
Re: Best 440 intake w/dominator carb [Re: dafixr] #2589910
12/10/18 05:00 PM
12/10/18 05:00 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Old school but I run the MP M1 intake on my 440.Its street driven with the 1050 Dominator.Runs great and even is decent on the street for being so radical.Rocky
Chrysler Firepower
Re: Best 440 intake w/dominator carb [Re: dafixr] #2589951
12/10/18 06:14 PM
12/10/18 06:14 PM
AndyF Offline
AndyF  Offline
Ok, that raises another question. Do you have standard port heads or MW port heads? If you have standard port heads then the Indy stuff won't fit. You might be able to find a Mopar M1 4500 intake. They work pretty well and are usually fairly inexpensive since they aren't super popular.
Re: Best 440 intake w/dominator carb [Re: dafixr] #2589955
12/10/18 06:20 PM
12/10/18 06:20 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The Super Victor is available with std ports for the RB block.
Re: Best 440 intake w/dominator carb [Re: dafixr] #2590065
12/10/18 09:25 PM
12/10/18 09:25 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The 4150 manifold is easy to convert to the 4500.
1) screw aluminum bolts into the bolt holes
2) cut them off flush
3) drill and tap the new 4500 pattern
4) open up the plenum to clear the 4500
I am not suggesting that the 4150 manifolds are better than the 4500 manifolds. Just a heads up on how easy it is to convert one. One of my favorite manifolds was a Holley Street Dominator that I converted that way. Worked real good and fit under the hood.
Master, again and still
Re: Best 440 intake w/dominator carb [Re: fast68plymouth] #2590077
12/10/18 09:39 PM
12/10/18 09:39 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
The Super Vic intakes are both the same casting imo,you can open the standard to max wedge . Plenty of meat there . That is what i did when going stockish to max wedge .
When fitting to non raised stock port i did have to cut a little top and bottom of intake face for clearance
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
