Good inexpensive engine kit #2589083
12/08/18 05:48 PM
12/08/18 05:48 PM
Table Rock Lake Missouri
furious Offline OP
furious  Offline OP
Hello, I haven't bought one in a while but I have a stock 318 I want to freshen up.
I am concerned with the little research I have done that most of this stuff might be Chinese now, correct?
I don't want to break the bank for bearings, gaskets, rings, cam, lifters, timing chain and oil pump but don't want junk either.
Can you give me some current insight? Recommendations?
Thanks in advance.
Re: Good inexpensive engine kit [Re: furious] #2589085
12/08/18 05:55 PM
12/08/18 05:55 PM
P
Porter67 Offline
Porter67  Offline
P
They sell oem king brand bearings on ebay at a good price. They also sell oem pistons ,some us at a great price.
Not knowing what year yours is some even 100k motors show little bore wear and could get by with a hone.
With oem pistons at around $125 a set with rings id consider new unworn pistons.
Also on enay are some good cam kits and cam, lifters, springs and chain all made by elgin.
Same thing for oil pumps if you take a few to look on ebay there is alot of good cheap 318 junk from the gov dumping all the mopar junk used in the military and oem good oil pumps are priced well below mosts.
So I dont see it being very hard to freshen up a teener with good parts without killing your wallet.
Re: Good inexpensive engine kit [Re: Porter67] #2589108
12/08/18 07:51 PM
12/08/18 07:51 PM
furious Offline OP
furious  Offline OP
Thanks so much, will check out Ebay. It is a 79 78k motor with virtually no cylinder wear so I am going to reuse the pistons.
Re: Good inexpensive engine kit [Re: furious] #2589113
12/08/18 08:16 PM
12/08/18 08:16 PM
Chicago
PurpleBeeper Offline
Chicago
You could always check your local parts stores, Mancini, Jegs, Summit, etc. for engine "re-ring" kits.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Good inexpensive engine kit [Re: furious] #2589120
12/08/18 08:27 PM
12/08/18 08:27 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
rockauto has them too
Don't be the exception.
Re: Good inexpensive engine kit [Re: Supercuda] #2589127
12/08/18 08:50 PM
12/08/18 08:50 PM
furious Offline OP
furious  Offline OP
Thanks, I have looked at all of those places but came away wondering about the origin of he product. I used to use Clevite 77 bearings, Fel Pro gaskets and sealed power rings. They all had names I had never heard of thus the reason for asking some of you that have had recent experience.
Re: Good inexpensive engine kit [Re: furious] #2589129
12/08/18 08:52 PM
12/08/18 08:52 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You never heard of Sealed Power? Cause RA has there stuff in kit form too
Re: Good inexpensive engine kit [Re: Supercuda] #2589134
12/08/18 08:55 PM
12/08/18 08:55 PM
furious Offline OP
furious  Offline OP
Yeah, as mentioned above, I have used a lot of sealed power. thanks, will look again as I buy almost weekly from Rock Auto.
Re: Good inexpensive engine kit [Re: Supercuda] #2589135
12/08/18 08:59 PM
12/08/18 08:59 PM
furious Offline OP
furious  Offline OP
Their sp kit comes with pistons which I don't want, they have a large selection of "engine tech" that I have never heard of.
Anyone used any of that stuff?
Re: Good inexpensive engine kit [Re: Supercuda] #2589138
12/08/18 09:11 PM
12/08/18 09:11 PM
furious Offline OP
furious  Offline OP
I just ordered everything from RA individually and got the name brands I trust. thanks
Re: Good inexpensive engine kit [Re: furious] #2589161
12/08/18 10:28 PM
12/08/18 10:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You must have missed the re-ring listing. Mains, rods, rings and gaskets Nothing else.
79 318 rering kit
Re: Good inexpensive engine kit [Re: Supercuda] #2589184
12/08/18 11:16 PM
12/08/18 11:16 PM
furious Offline OP
furious  Offline OP
79 318 rering kit
Thanks, I saw that but have never heard of "Engine Tech."
Re: Good inexpensive engine kit [Re: furious] #2589231
12/09/18 01:42 AM
12/09/18 01:42 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not talking about the engine tech listings, the last four listings in the link are Sealed Power kits with Sealed Power parts in the kits.
Re: Good inexpensive engine kit [Re: Supercuda] #2589300
12/09/18 12:39 PM
12/09/18 12:39 PM
furious Offline OP
furious  Offline OP
Thanks, I see now and appreciate your patience.
I ended up buying the Seal Power rings, Clevite tri metal bearings and Fel Pro gaskets, everything individually for about $20 less than the Sealed Power kit price. :-)
