What tools do I need to set up a dana? #2588735
12/07/18 07:38 PM
12/07/18 07:38 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
I have the big torque wrenches and indicators..what else do I need? Any good paperback manuals you can recommend also?
Re: What tools do I need to set up a dana? [Re: Hot 340] #2588751
12/07/18 08:07 PM
12/07/18 08:07 PM
Boise
Moparteacher Offline
Boise
Inch lb. torque wrench, analog, to measure pinion rotational torque. Gear marking grease. Punch for marking cap side and orientation. Pinion flange holder.
Re: What tools do I need to set up a dana? [Re: Hot 340] #2588753
12/07/18 08:09 PM
12/07/18 08:09 PM
Boise
Boise
Shims or threaded side adjusters? Shims and you'll want a case spreader. Side adjusters and you'll need an adjuster wrench or a tapered punch.
Re: What tools do I need to set up a dana? [Re: Hot 340] #2588754
12/07/18 08:12 PM
12/07/18 08:12 PM
Boise
Boise
Best manual on the market is Randy's Ring & Pinion book.
https://www.randysworldwide.com/product/rpsbook-01/
Re: What tools do I need to set up a dana? [Re: Moparteacher] #2588770
12/07/18 08:55 PM
12/07/18 08:55 PM
Rancho Cordova, California (Sa...
hemi71x Online content
hemi71x  Online Content
Yes, and or, the factory maintenance manual will tell all.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: What tools do I need to set up a dana? [Re: Hot 340] #2588778
12/07/18 09:12 PM
12/07/18 09:12 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Bearing puller or setup bearings, case spreader if you need it, mag base for dial indicator, someone to show you how. That should cover everything including what others have said.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: What tools do I need to set up a dana? [Re: Hot 340] #2588843
12/07/18 11:14 PM
12/07/18 11:14 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'm doing mine right now. Polish the front pinion bearing area so you can slide the front pinion bearing on. You'll need the correct size piece of tube to press the pinion head bearing on. I made slip fit test side carrier bearings as well. No need for a case spreader. Remember when adding pinion depth shim, add pinion preload shims and vice versa. I've found the pinion depth tool to be inaccurate. Best start with the old shim and go from there. The final install of the carrier should take some press with a soft face hammer to get it in. So you need a dial indicator, torque wrench, marking compound, tools to remove and install pinion head bearing and side bearings, dial style inch pound torque wrench,race drivers for the pinion bearing races. Most of all patience, as every pinion shim change requires preload shim and side bearing shim changes.
Doug
Re: What tools do I need to set up a dana? [Re: Hot 340] #2588858
12/07/18 11:47 PM
12/07/18 11:47 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Re: What tools do I need to set up a dana? [Re: Hot 340] #2588943
12/08/18 04:06 AM
12/08/18 04:06 AM
I suggest making a set of set up bearings for the pinion shaft up, You can use the old ones you have for that and use a new set on the new pinion gear up
The set up bearings inner race will need to be honed out with a small cylinder hone or a flapper wheel on a small dremil bit, your choice scope
They need to be loose enough to slide on with very little pressure, not sloppy loose though tsk This will allow you to experiment with the shims to get it set up dead nuts up, Same thing on the carrier bearings inner races also if your reusing a older Dana 60 wrench
As already mention a good mag base and dial indicator with a accurate inch lb. torque wrench are needed, buy yourself a complete Dodge or Plymouth factory service manual, 1966 to 1971, and read the Dana 60 rear end section thoroughly so you under stand exactly what you need to do to get the pinion depth and the ring gear pattern within tolerances on setting up both the ring gear and the pinion bearing depth and preload along with the backlash and carrier bearing preload as well as getting both(coast and drivepatterns) patterns correct up scope
I have never used a case spreader, I use two pry bars to pry the case out of the housing and a plastic mallet to install it using the carrier bearings as the guide into the carrier bearing seats hammer grin Using this methods requires you to find out EXACTLY what zero carrier bearing preload shims are needed to achieve that, once you have that then you need to add from .013 to .017 more shim width to get the proper carrier bearing preload, use what your FSM recommends scope up
Setting up a Dana 60 is like anything new, the first time is usually the hardest shruggy
Re: What tools do I need to set up a dana? [Re: Hot 340] #2588947
12/08/18 04:11 AM
12/08/18 04:11 AM
Southern Oregon
toyotajeep Offline
toyotajeep  Offline
Southern Oregon
Same as everyone else has said. Agree on set up bearings, Also there’s tons of build ups online and other things because that axle is used in the front end of most rock crawlers. I have done a lot of axles in trucks and never used a case spreader. Pry bars etc have worked for me.
1989 Dodge Cummins & 1989 Dodge W-250
Re: What tools do I need to set up a dana? [Re: Hot 340] #2589005
12/08/18 12:45 PM
12/08/18 12:45 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I press the big bearing on the pinion and put the shims under the bearing race..... so a long brass punch and race installer comes in handy. I think you’ll find what a godsend the S60 with side adjuster are when you’re done smile
Re: What tools do I need to set up a dana? [Re: Hot 340] #2589006
12/08/18 12:55 PM
12/08/18 12:55 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Lots of good advise here.
Don't forget to bring patience of biblical proportions, an undying will for perfection, and the ability to find joy in taking things apart, and putting them back together, endless times. lol.
Seriously, if you're pulling a good gear out. Keep every piece of it together as a setup. Same spool, or carrier, bearings, shims whatever. Then if you ever want to return to that ratio/set up, it's a bolt it in, no setup required, and go cat go.
Like Jbody said,,side adjusters are just too cool for words.
Re: What tools do I need to set up a dana? [Re: Hot 340] #2589014
12/08/18 01:24 PM
12/08/18 01:24 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
Case of beer and then the number of somebody that can show you all the tricks to doing the set-up! Dana 60's are a real PITA unless you have done them before! A set of mock-up bearings are a must. I agree the S-60 is about the best thing that ever happened to a Dana.
Re: What tools do I need to set up a dana? [Re: dthemi] #2589015
12/08/18 01:25 PM
12/08/18 01:25 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Someone had a good post recently about taking a fine flat file and spending a few minutes deburing gears before starting assembly. I know that a few minutes removing the high spots around the bolt holes from threading them sure makes things easier.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What tools do I need to set up a dana? [Re: pittsburghracer] #2589041
12/08/18 03:25 PM
12/08/18 03:25 PM
Alberta
440_Offroader Offline
Alberta
You want to use new bearings for set up bearings too. I tried using used bearings for set up, and when you have the new bearings on for final assembly, your measurements will be not the same. IIRC my backlash was 0.004" different.
Re: What tools do I need to set up a dana? [Re: Hot 340] #2589055
12/08/18 04:04 PM
12/08/18 04:04 PM
Boise
Boise
Set up bearings are great but expensive. You can make your own pinion set up bearing, like Cab mentioned, but you'll want to use a new bearing which means you're purchasing two expensive bearings. Shims under the cup race is easier but requires an assortment of shims made for that cup.
You can purchase a set up bearing through Randy's or make your own, but honing a bearing cone race is time consuming and will wear out a set of honing stones before you've removed enough material for a slip-on fit. I've done it. It'll require you to increase the ID about .004". And this is bearing material!
Another option to all this bearing on and off crap is to use a pinion depth tool. The good ones will cost more than you'll want to spend unless you're doing this for a living, but a cheap one can be had from Summit or Jegs for about $80, Ratech makes a simple tool, but requires bearing removal. #10009 for $29.
Re: What tools do I need to set up a dana? [Re: Hot 340] #2589084
12/08/18 05:51 PM
12/08/18 05:51 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Do yourself a favor and go on u-tube and watch the jantz engineering videos on gear setup, best and fastest I have ever seen. Buy or make setup bearings, jantz has a video for that too. East coast gear has decent price on setup bearings, they are worth buying or making.
Re: What tools do I need to set up a dana? [Re: Hot 340] #2589117
12/08/18 08:24 PM
12/08/18 08:24 PM
Boise
Boise
Good info.
Re: What tools do I need to set up a dana? [Re: Hot 340] #2589118
12/08/18 08:25 PM
12/08/18 08:25 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
The rag trick for popping the carrier out is the best trick I learned.
Roll a rag in between the ring and pinion mesh and pry on the ring gear bolts.
Re: What tools do I need to set up a dana? [Re: 65Fury440] #2589139
12/08/18 09:11 PM
12/08/18 09:11 PM
You can( I do) use the ring gear bolts without the rag to pry the center section out up twocents
OP I forgot to mention that I do have and use a pinion depth tool kit also sold by T&D that Bill Bagshaw use to sell under his house name of Pro Parts, I use it on new gears all the time up
On reusing used gears you almost have to go by the pattern before and after, good luck on your build up
