denso alt plug #2588505
12/07/18 11:34 AM
12/07/18 11:34 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
does anyone know where to get the round 3 wire plug for the denso 60 amp alt.
Re: denso alt plug [Re: bonefish] #2588508
12/07/18 11:46 AM
12/07/18 11:46 AM
E
earlymopar Offline
earlymopar  Offline
E
Ebay is where I bought mine for roughly $6.
- EM
Re: denso alt plug [Re: bonefish] #2588513
12/07/18 11:58 AM
12/07/18 11:58 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I think Autozone has them also.
Re: denso alt plug [Re: earlymopar] #2588554
12/07/18 01:22 PM
12/07/18 01:22 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
- EM
thats prob what ill check,just cant get on the site.
Re: denso alt plug [Re: Stanton] #2588555
12/07/18 01:24 PM
12/07/18 01:24 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
i checked there but their english speaking guy is out sick.napa was no good on line mabey if i go down in person it will help.
Re: denso alt plug [Re: bonefish] #2588574
12/07/18 01:47 PM
12/07/18 01:47 PM
AndyF Offline
AndyF  Offline
Re: denso alt plug [Re: bonefish] #2588620
12/07/18 03:02 PM
12/07/18 03:02 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Mind if I tag along for a related question:
Are they all the same?
Is the Chevy sprint plug the same as the Celica plug?
Suspecting they are different but haven't bought it all to find out.
Rich H.
Esse Quam Videri
Re: denso alt plug [Re: bonefish] #2588621
12/07/18 03:06 PM
12/07/18 03:06 PM
AndyF Offline
AndyF  Offline
You really need to look in a Denso catalog to know the answer. The plug I sell is for the Denso alternator kits that I sell. However, I know from flipping thru the catalog that most Denso 3 prong plugs use the same socket.
Re: denso alt plug [Re: ZIPPY] #2588805
12/07/18 10:04 PM
12/07/18 10:04 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
If you are using a Celica alt it should be from an older car, rear drive 22RE engine. I suggest the numbers from Andy's site because he already went through the headache of producing a bracket that works.
Later model Toyota alternators 2000 ish started using an oval plug and ribbed belts.
Gus beer
64 Plymouth Savoy
Dana 60
Re: denso alt plug [Re: bonefish] #2588877
12/08/18 12:43 AM
12/08/18 12:43 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Oriole's has a good selection of them here and I found a plug for my 3 wire GM alt(CS130). Kinda pricey but it was worth the cost to be able to verify it was exactly what I needed.
68 Barracuda Formula S 340
Re: denso alt plug [Re: bonefish] #2589148
12/08/18 10:00 PM
12/08/18 10:00 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
I just use female spade connectors
....BAD A$$ STREET CAR.....
