Re: denso alt plug
[Re: earlymopar]
#2588554
12/07/18 01:22 PM
12/07/18 01:22 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Ebay is where I bought mine for roughly $6.
- EM thats prob what ill check,just cant get on the site.
Re: denso alt plug
[Re: Stanton]
#2588555
12/07/18 01:24 PM
12/07/18 01:24 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
I think Autozone has them also. i checked there but their english speaking guy is out sick.napa was no good on line mabey if i go down in person it will help.
Re: denso alt plug
[Re: bonefish]
#2588620
12/07/18 03:02 PM
12/07/18 03:02 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
Mind if I tag along for a related question:
Are they all the same? Is the Chevy sprint plug the same as the Celica plug?
Suspecting they are different but haven't bought it all to find out.
Rich H.
Esse Quam Videri
Re: denso alt plug
[Re: ZIPPY]
#2588805
12/07/18 10:04 PM
12/07/18 10:04 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
Suspecting they are different but haven't bought it all to find out. If you are using a Celica alt it should be from an older car, rear drive 22RE engine. I suggest the numbers from Andy's site because he already went through the headache of producing a bracket that works. Later model Toyota alternators 2000 ish started using an oval plug and ribbed belts. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: denso alt plug
[Re: bonefish]
#2588877
12/08/18 12:43 AM
12/08/18 12:43 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Oriole's has a good selection of them here and I found a plug for my 3 wire GM alt(CS130). Kinda pricey but it was worth the cost to be able to verify it was exactly what I needed.
68 Barracuda Formula S 340
