4500 14" Drop Base Air Cleaner Bottom #2588039
12/06/18 01:30 PM
12/06/18 01:30 PM
Spring Hill Fl
65Fury440 Offline OP
Spring Hill Fl
Anyone know where to get a 4500 drop base bottom pan only?
Need it to start an air pan to seal the carb to scoop.
Holley makes one, but doesn't sell the bottom piece by itself.
https://www.holley.com/products/fuel_systems/air_cleaners/air_cleaner_assemblies/parts/120-4660
Re: 4500 14" Drop Base Air Cleaner Bottom [Re: 65Fury440] #2588047
12/06/18 01:48 PM
12/06/18 01:48 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 4500 14" Drop Base Air Cleaner Bottom [Re: 65Fury440] #2588051
12/06/18 01:50 PM
12/06/18 01:50 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Re: 4500 14" Drop Base Air Cleaner Bottom [Re: 65Fury440] #2588055
12/06/18 01:52 PM
12/06/18 01:52 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Re: 4500 14" Drop Base Air Cleaner Bottom [Re: 65Fury440] #2588060
12/06/18 01:54 PM
12/06/18 01:54 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
www.ramairbox.com. They have dominator drop bases.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: 4500 14" Drop Base Air Cleaner Bottom [Re: steve660] #2588202
12/06/18 06:53 PM
12/06/18 06:53 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
http://www.universalspinners.com/photo-gallery.php
They make 16" drop base filter setups for 4500 carbs...
Re: 4500 14" Drop Base Air Cleaner Bottom [Re: 65Fury440] #2588261
12/06/18 08:25 PM
12/06/18 08:25 PM
Spring Hill Fl
Spring Hill Fl
A 14" base would make the fab of the air pan better.
Thanks for the help everyone.
Re: 4500 14" Drop Base Air Cleaner Bottom [Re: 65Fury440] #2588367
12/07/18 12:21 AM
12/07/18 12:21 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Do not think you can get a 14" drop base for 4500
1963 Plymouth Max Wedge
1971 Barracuda
Re: 4500 14" Drop Base Air Cleaner Bottom [Re: ozymaxwedge] #2588454
12/07/18 06:39 AM
12/07/18 06:39 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
[quote=ozymaxwedge]Do not think you can get a 14" drop base for 4500 [wr/quote]
I think you are right . I found 16 but that wont fit
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 4500 14" Drop Base Air Cleaner Bottom [Re: tex013] #2588488
12/07/18 10:25 AM
12/07/18 10:25 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i have 3 14 in drop base 4500 bottoms on 3 diff. cars, i beleive the last one i got was from K&N. shruggy
