Re: 4500 14" Drop Base Air Cleaner Bottom
[Re: 65Fury440]
#2588060
12/06/18 01:54 PM
12/06/18 01:54 PM
Posts: 289 Lowes
steve660
Lowes
www.ramairbox.com. They have dominator drop bases.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
[Re: 65Fury440]
#2588367
12/07/18 12:21 AM
12/07/18 12:21 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Do not think you can get a 14" drop base for 4500
1963 Plymouth Max Wedge 1971 Barracuda
[Re: ozymaxwedge]
#2588454
12/07/18 06:39 AM
12/07/18 06:39 AM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
[quote=ozymaxwedge]Do not think you can get a 14" drop base for 4500 [wr/quote]
I think you are right . I found 16 but that wont fit
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
