Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? #2587096
12/04/18 05:12 PM
12/04/18 05:12 PM
Alabama
David1971 Offline OP
Alabama
Did all 70 model Cuda U-codes have a carburetor solenoid, even if it is a non AC car with auto transmission? I see the lead for it, but no solenoid. there is dashpot instead. The AVS is a 4617SA dated J9 which matches the build date of the car (fender tag)
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? [Re: David1971] #2587107
12/04/18 05:53 PM
12/04/18 05:53 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The wire lead is there no matter what.
I thought the 440 four barrel did not have the solenoid but was going to double check when I got home
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? [Re: David1971] #2587110
12/04/18 05:55 PM
12/04/18 05:55 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes all 1970 440 U code cars should have an idle stop solenoid (and no dashpot). That is a 69 440 4 speed carburetor you have, my gues is that it got swapped in the past.
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? [Re: David1971] #2587114
12/04/18 06:03 PM
12/04/18 06:03 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Pretty sure a 440 auto with A/C should have a Carter AVS 4741.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? [Re: 70gtx440dana] #2587304
12/05/18 01:28 AM
12/05/18 01:28 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
His car is non-AC
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? [Re: ScottSmith_Harms] #2587337
12/05/18 02:47 AM
12/05/18 02:47 AM
Alabama
Alabama
Scott, since the date code on the carb base is October 1969 (J9),wouldn't that indicate that this carburetor would have been installed on a 1970 production 440 car?
Also, I have attached another picture. What do you make of the ink stamping on the backside of the body?
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? [Re: David1971] #2587344
12/05/18 03:32 AM
12/05/18 03:32 AM
Lansing, MI
Lansing, MI
Pretty sure the SA at the end of the part number indicates it is a service part. Someone with more detail should chime in. By the way the 70 440-4 auto no A/C carb part numbers are 4738S and 4740S. Sorry for the misinformation on the 4741S.
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? [Re: David1971] #2587359
12/05/18 04:12 AM
12/05/18 04:12 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
As 70gtx mentioned, the SA is an indicator of a replacement (while I would not say all SA's were replacements). The date simply means that it was made as a replacement for a 69 440 after 69 model year production ended. It's not correct for your car, I'm sure on that one. Various ink stampings are commonly seen on carbs, I've seen that one on 69 AVS carbs before but I don't know the specific meaning, likey an inspectors stamp or a to quickly visually identify it (The airhorn or complete assembly) for the application at the Carter facility.
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? [Re: David1971] #2587404
12/05/18 10:54 AM
12/05/18 10:54 AM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
J9 is actually September 1969, the "I" is not used as it too much resembles a "1". H9 would be August 1969, K9 would be October 1969, etc.
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? [Re: David1971] #2587418
12/05/18 11:41 AM
12/05/18 11:41 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Also, yes, what Dwight said iagree
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? [Re: David1971] #2587650
12/05/18 05:59 PM
12/05/18 05:59 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
Were the Idle Solenoids the same basic unit that is on 6-pac cars (except for mounting bracket)?
I had heard these were made by Delco-Remy. Were they available as over the counter items as well?
Didn't Dales Cuda shop reproduce them at one point?
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? [Re: David1971] #2587668
12/05/18 06:39 PM
12/05/18 06:39 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Cool to see a dark green '70 Cuda with the matching, extra cost bench seat. beer
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? [Re: Alaskan_TA] #2587690
12/05/18 07:11 PM
12/05/18 07:11 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Not all the same, the one you need is a DR1144421, they have a seperate bracket to hold them to the carb and a special lever that bolts to the throttle shaft that is required. These are not reproduced, most can be restored, cores vary in price, ebay is your friend, or try www.tonysparts.com.
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? [Re: David1971] #2587766
12/05/18 09:23 PM
12/05/18 09:23 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
that's not a solenoid. it's a dashpot that was used on smog era 4spd avs engines.
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? [Re: lewtot184] #2587863
12/06/18 01:11 AM
12/06/18 01:11 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
This is the correct solenoid.
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? [Re: David1971] #2587878
12/06/18 01:36 AM
12/06/18 01:36 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, Bill's example shows the one you need, here are a couple more pics, one showing the correct arm that bolts to the throttle shaft that the plunger head contacts.
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? [Re: ScottSmith_Harms] #2588228
12/06/18 07:29 PM
12/06/18 07:29 PM
RT03 Offline
RT03  Offline
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? [Re: David1971] #2588284
12/06/18 09:14 PM
12/06/18 09:14 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Proper brackets and part#s yes, but being ink stamped replacements they will not have the stamped into the steel number of production line units so accordingly, are less correct/valuable. Totally usable though plus youll still need the throttle shaft lever.
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? [Re: ScottSmith_Harms] #2588358
12/07/18 12:09 AM
12/07/18 12:09 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
What Scott said and also this,the brass cap terminal in the adjusting stud.
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids?? [Re: ScottSmith_Harms] #2588363
12/07/18 12:14 AM
12/07/18 12:14 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
What Scott said and this,the brass cap terminal on the end of the adjusting stud.
