Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids??
#2587096
12/04/18 05:12 PM
12/04/18 05:12 PM
Posts: 203 Alabama
David1971
Alabama
Did all 70 model Cuda U-codes have a carburetor solenoid, even if it is a non AC car with auto transmission? I see the lead for it, but no solenoid. there is dashpot instead. The AVS is a 4617SA dated J9 which matches the build date of the car (fender tag)
Re: Carter AVS: All 1970 Cuda 440's U-codes had carb solenoids??
[Re: David1971]
#2587114
12/04/18 06:03 PM
12/04/18 06:03 PM
Posts: 3,527 Lansing, MI
70gtx440dana
Lansing, MI
Pretty sure a 440 auto with A/C should have a Carter AVS 4741.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: 70gtx440dana]
#2587304
12/05/18 01:28 AM
12/05/18 01:28 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Pretty sure a 440 auto with A/C should have a Carter AVS 4741. His car is non-AC
[Re: David1971]
#2587344
12/05/18 03:32 AM
12/05/18 03:32 AM
70gtx440dana
Lansing, MI
Pretty sure the SA at the end of the part number indicates it is a service part. Someone with more detail should chime in. By the way the 70 440-4 auto no A/C carb part numbers are 4738S and 4740S. Sorry for the misinformation on the 4741S.
[Re: David1971]
#2587404
12/05/18 10:54 AM
12/05/18 10:54 AM
Posts: 1,652 Calgary, Alberta Canada
m46rat
Scott, since the date code on the carb base is October 1969 (J9),wouldn't that indicate that this carburetor would have been installed on a 1970 production 440 car? Also, I have attached another picture. What do you make of the ink stamping on the backside of the body? J9 is actually September 1969, the "I" is not used as it too much resembles a "1". H9 would be August 1969, K9 would be October 1969, etc.
[Re: lewtot184]
#2587863
12/06/18 01:11 AM
12/06/18 01:11 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
that's not a solenoid. it's a dashpot that was used on smog era 4spd avs engines. This is the correct solenoid.
