99 dodge 1500 rear end whine #2587042
12/04/18 03:04 PM
12/04/18 03:04 PM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
99 dodge truck rearend whine . Is this a commom problem ? easy fix? any help appreciated.
Re: 99 dodge 1500 rear end whine [Re: 3wracing] #2587082
12/04/18 04:38 PM
12/04/18 04:38 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Check the pinion nut for tightness, they're known to come loose.
Re: 99 dodge 1500 rear end whine [Re: 3wracing] #2587102
12/04/18 05:29 PM
12/04/18 05:29 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Pinion bearings growl from start to hwy speed is the only common issue that I know of, whether nut comes loose or not.
Re: 99 dodge 1500 rear end whine [Re: 3wracing] #2587209
12/04/18 09:50 PM
12/04/18 09:50 PM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
place rear of truck on jack stands
remove rear wheels and brake drums
disconnect driveshaft
pinion shaft should turn smoothly
if it turns with any jerky motion , pinion bearings and/or axle assembly is bad
this applies to any replacement axle assembly as well , it MUST turn smooth at the pinion shaft
Re: 99 dodge 1500 rear end whine [Re: 3wracing] #2587274
12/05/18 12:03 AM
12/05/18 12:03 AM
northeast pa
3wracing Offline OP
3wracing  Offline OP
northeast pa
thank you
Re: 99 dodge 1500 rear end whine [Re: 3wracing] #2587297
12/05/18 01:14 AM
12/05/18 01:14 AM
Brookville Pa
crowbait Offline
crowbait  Offline
Brookville Pa
Limited slips tend to break the retainer clips and grind on the housing.
