#2587042 - 12/04/18 12:04 PM 99 dodge 1500 rear end whine
3wracing Offline
Loc: northeast pa
99 dodge truck rearend whine . Is this a commom problem ? easy fix? any help appreciated.
#2587082 - 12/04/18 01:38 PM Re: 99 dodge 1500 rear end whine [Re: 3wracing]
John_Kunkel Offline
Loc: Rio Linda, CA
Check the pinion nut for tightness, they're known to come loose.
I'm supposed to respect my elders, but its getting harder and harder for me to find one now.
#2587102 - 12/04/18 02:29 PM Re: 99 dodge 1500 rear end whine [Re: 3wracing]
buildanother Offline
Loc: chicagoland,usa
Pinion bearings growl from start to hwy speed is the only common issue that I know of, whether nut comes loose or not.
#2587209 - 12/04/18 06:50 PM Re: 99 dodge 1500 rear end whine [Re: 3wracing]
iapco103 Offline
Loc: Conroe , Texas
place rear of truck on jack stands
remove rear wheels and brake drums
disconnect driveshaft
pinion shaft should turn smoothly
if it turns with any jerky motion , pinion bearings and/or axle assembly is bad
this applies to any replacement axle assembly as well , it MUST turn smooth at the pinion shaft
#2587274 - 12/04/18 09:03 PM Re: 99 dodge 1500 rear end whine [Re: 3wracing]
3wracing Offline
Loc: northeast pa
thank you
#2587297 - 12/04/18 10:14 PM Re: 99 dodge 1500 rear end whine [Re: 3wracing]
crowbait Offline
Loc: Brookville Pa
Limited slips tend to break the retainer clips and grind on the housing.
25,738 Registered Members
192,835 Topics
1971 HEMICUDA HISTORY SEARCHING.. BS23R1B CAR
by 71redcuda
02/16/19 03:46 AM
6.4 BGE block
by HOTMOPR
02/16/19 12:11 AM
Couple Pertronix questions....
by gss
02/15/19 11:00 PM
Adopt a pet
by Superfreak
02/15/19 10:43 PM
