Need Some Help.. Looking For SB Heads #2586179
12/02/18 04:18 PM
12/02/18 04:18 PM
MR_P_BODY Offline OP
I am thinking about buying a new set of heads
for my street rod.. its a 416CI.. its been so
long since I bought ANYTHING new I dont even
know what heads are out there... can you guys
give me some ideas.. looking for alum SB stuff
TIA.. I have a couple of sets of MP heads now
but would like some newer stuff.. thanks
wave
Re: Need Some Help.. Looking For SB Heads [Re: MR_P_BODY] #2586211
12/02/18 05:37 PM
12/02/18 05:37 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Only two new heads have come out since the Jurassic era.
The eddie Victors
The Trick Flow for SB
Victor is offset TF will take standard rockers and headers
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Need Some Help.. Looking For SB Heads [Re: B3422W5] #2586238
12/02/18 06:44 PM
12/02/18 06:44 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
The eddie Victors
m
Let’s restate this as the TrickFlow heads aren’t released yet. Maybe one of these days but they are now losing sales.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Need Some Help.. Looking For SB Heads [Re: MR_P_BODY] #2586254
12/02/18 07:21 PM
12/02/18 07:21 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Hi Mike, if edelbrock-based stuff is of any interest I have -one- single p5153850 head. It's like edelbrock rpm but the pushrod pinch is totally gone, and the port is straight. For you it will be dirt cheap. You would have to come up with a matching one someplace. I'll text or email you pics, if interested give me a shout. Rich
Rich H.
Esse Quam Videri
Re: Need Some Help.. Looking For SB Heads [Re: MR_P_BODY] #2586282
12/02/18 08:27 PM
12/02/18 08:27 PM
AndyF Online content
AndyF  Online Content
Last time I looked at SB stuff I came to the conclusion that Hughes Engines had some good options. They buy raw Edelbrock castings and finish them. I'd probably go that way if someone forced me to work on a SB engine. Other option would be to call Brian at IMM and ask him what he recommends. He always has some good SB thoughts.
Re: Need Some Help.. Looking For SB Heads [Re: MR_P_BODY] #2586340
12/02/18 10:11 PM
12/02/18 10:11 PM
Washington
madscientist Offline
Washington
I'm not sure what Mr P would go backwards in cylinder head with ANY of the heads mentioned even if he has some lowly CI W-2 stuff laying around.
No way would I build an engine with OE architecture when I have the option of something else.
But that's just me.
Unless of course I wanted to keep the power down for whatever reason. They I'd look at other stuff.
Re: Need Some Help.. Looking For SB Heads [Re: madscientist] #2586354
12/02/18 10:33 PM
12/02/18 10:33 PM
Right now I have 2 sets of W-2s and 1 set of
W-5s.. all of them ported.. all flowing over
300cfm.. my W-5s are almost 320 cfm.. I'm
just looking and wondering whats out there
wave
Re: Need Some Help.. Looking For SB Heads [Re: MR_P_BODY] #2586360
12/02/18 10:45 PM
12/02/18 10:45 PM
gregsdart Offline
gregsdart  Offline
Wha600t rpm range? Very good low rpm manners important? I hope to learn a bit from this discusion. Would a ported Magnum style head do the trick? Out of breath by 6500 maybe, but great torque/low rpm? I would guess 550 hp potential by 6000 rpm with a somewhat streetable cam.
Re: Need Some Help.. Looking For SB Heads [Re: gregsdart] #2586372
12/02/18 11:00 PM
12/02/18 11:00 PM
My stuff now days is injected and I am running
7200 rpms at the stripe and yes I want nice
drive ability.. right now it has some lope to
it and drives pretty nice.. I still want to
lean it down just a little
wave
Re: Need Some Help.. Looking For SB Heads [Re: MR_P_BODY] #2586388
12/02/18 11:36 PM
12/02/18 11:36 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
The CNC vic head is really a good head.
Nice casting and can make 750 HP With a small cross section. 2.5"
With the stock program.
My program can make 1000+ HP with the pro port casting.
Re: Need Some Help.. Looking For SB Heads [Re: MR_P_BODY] #2586417
12/03/18 12:53 AM
12/03/18 12:53 AM
Az
Crizila Offline
Crizila  Offline
Az
wave
This is what I ran on my 300 Mike. They are Edelbrocks fully CNC ported by Hughes. I never flowed them but Hughes claimed 300cfm @.700 lift.
Fastest 300
Re: Need Some Help.. Looking For SB Heads [Re: MR_P_BODY] #2586473
12/03/18 06:39 AM
12/03/18 06:39 AM
Earth
Rob C Offline
Rob C  Offline
Earth
What exactly is the goal? What parts are we n the 416?
We could use a bigger picture of it all.
FWIW, which ain’t worth much, LOL!
https://promaxxperformance.com/product/shocker-185-mopar-cnc/
Re: Need Some Help.. Looking For SB Heads [Re: Rob C] #2586624
12/03/18 03:12 PM
12/03/18 03:12 PM
This is my street rod.. it goes to the track a
few times but mainly just street driven.. most
of the parts I had in the shop so I built a
spare engine so I could get stuff out of the
way.. I will put it in maybe next spring when
I get back home.. If I want I might put back
in the race car but set it up for street
driving.. right now I have W-5s on it
wave
Re: Need Some Help.. Looking For SB Heads [Re: MR_P_BODY] #2586657
12/03/18 04:01 PM
12/03/18 04:01 PM
Earth
Rob C Offline
Rob C  Offline
Earth
OK, it’s a 416 w/W5 heads on it now.
I have to ask about the cam duration and gears.
I don’t see a problem running the W5 on the street. Is there something about the head that gives you the willies not to run it? If your in the frame of mind that you have an overkill set of heads on a mild engine, I get that, but, I would say not to sweat it. The excellent head will help carry the smaller cam longer and be a really efficient and effective package.
Without knowing about the rear gear and stall rate, just purely for example, a small lowly hyd. cam like 230*/236*/240* intake duration will work for the street like we all know how it does and the heads will help carry the rpm range further up the rpm scale. The duration is super streetable with great top end with the heads you have on there now.
I really don’t know what to tell ya there buddy. Time for a little soul searching. wink
Re: Need Some Help.. Looking For SB Heads [Re: Rob C] #2586814
12/03/18 11:11 PM
12/03/18 11:11 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Mike, if your not in a hurry then you may want to check out the TF heads when they become available, if they did their homework on the smallblock heads like they did on the Bigblock heads then they will be a nice street/strip deal.
