Need Some Help.. Looking For SB Heads
#2586179
12/02/18 04:18 PM
12/02/18 04:18 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I am thinking about buying a new set of heads for my street rod.. its a 416CI.. its been so long since I bought ANYTHING new I dont even know what heads are out there... can you guys give me some ideas.. looking for alum SB stuff TIA.. I have a couple of sets of MP heads now but would like some newer stuff.. thanks
Re: Need Some Help.. Looking For SB Heads
[Re: MR_P_BODY]
#2586211
12/02/18 05:37 PM
12/02/18 05:37 PM
Posts: 11,707 Portage,michigan
B3422W5
Portage,michigan
Only two new heads have come out since the Jurassic era. The eddie Victors The Trick Flow for SB Victor is offset TF will take standard rockers and headers
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2586238
12/02/18 06:44 PM
12/02/18 06:44 PM
Posts: 20,154 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Only two new heads have come out since the Jurassic era. The eddie Victors The Trick Flow for SB Victor is offset TF will take standard rockers and headers m Let’s restate this as the TrickFlow heads aren’t released yet. Maybe one of these days but they are now losing sales.
[Re: MR_P_BODY]
#2586254
12/02/18 07:21 PM
12/02/18 07:21 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
Hi Mike, if edelbrock-based stuff is of any interest I have -one- single p5153850 head. It's like edelbrock rpm but the pushrod pinch is totally gone, and the port is straight. For you it will be dirt cheap. You would have to come up with a matching one someplace. I'll text or email you pics, if interested give me a shout. Rich
Rich H.
Esse Quam Videri
[Re: MR_P_BODY]
#2586340
12/02/18 10:11 PM
12/02/18 10:11 PM
Posts: 4,457 Washington
madscientist
Washington
I'm not sure what Mr P would go backwards in cylinder head with ANY of the heads mentioned even if he has some lowly CI W-2 stuff laying around.
No way would I build an engine with OE architecture when I have the option of something else.
But that's just me.
Unless of course I wanted to keep the power down for whatever reason. They I'd look at other stuff.
[Re: madscientist]
#2586354
12/02/18 10:33 PM
12/02/18 10:33 PM
MR_P_BODY
Right now I have 2 sets of W-2s and 1 set of W-5s.. all of them ported.. all flowing over 300cfm.. my W-5s are almost 320 cfm.. I'm just looking and wondering whats out there
[Re: MR_P_BODY]
#2586360
12/02/18 10:45 PM
12/02/18 10:45 PM
Posts: 9,985 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Wha600t rpm range? Very good low rpm manners important? I hope to learn a bit from this discusion. Would a ported Magnum style head do the trick? Out of breath by 6500 maybe, but great torque/low rpm? I would guess 550 hp potential by 6000 rpm with a somewhat streetable cam.
[Re: gregsdart]
#2586372
12/02/18 11:00 PM
12/02/18 11:00 PM
MR_P_BODY
My stuff now days is injected and I am running 7200 rpms at the stripe and yes I want nice drive ability.. right now it has some lope to it and drives pretty nice.. I still want to lean it down just a little
[Re: MR_P_BODY]
#2586417
12/03/18 12:53 AM
12/03/18 12:53 AM
Posts: 7,506 Az
Crizila
Az
I am thinking about buying a new set of heads for my street rod.. its a 416CI.. its been so long since I bought ANYTHING new I dont even know what heads are out there... can you guys give me some ideas.. looking for alum SB stuff TIA.. I have a couple of sets of MP heads now but would like some newer stuff.. thanks This is what I ran on my 300 Mike. They are Edelbrocks fully CNC ported by Hughes. I never flowed them but Hughes claimed 300cfm @.700 lift.
Fastest 300
[Re: Rob C]
#2586624
12/03/18 03:12 PM
12/03/18 03:12 PM
MR_P_BODY
This is my street rod.. it goes to the track a few times but mainly just street driven.. most of the parts I had in the shop so I built a spare engine so I could get stuff out of the way.. I will put it in maybe next spring when I get back home.. If I want I might put back in the race car but set it up for street driving.. right now I have W-5s on it
[Re: MR_P_BODY]
#2586657
12/03/18 04:01 PM
12/03/18 04:01 PM
Posts: 792 Earth
Rob C
Earth
OK, it’s a 416 w/W5 heads on it now. I have to ask about the cam duration and gears. I don’t see a problem running the W5 on the street. Is there something about the head that gives you the willies not to run it? If your in the frame of mind that you have an overkill set of heads on a mild engine, I get that, but, I would say not to sweat it. The excellent head will help carry the smaller cam longer and be a really efficient and effective package. Without knowing about the rear gear and stall rate, just purely for example, a small lowly hyd. cam like 230*/236*/240* intake duration will work for the street like we all know how it does and the heads will help carry the rpm range further up the rpm scale. The duration is super streetable with great top end with the heads you have on there now. I really don’t know what to tell ya there buddy. Time for a little soul searching.
[Re: Rob C]
#2586814
12/03/18 11:11 PM
12/03/18 11:11 PM
dartman366
Mt. Vernon, Ohio
Mike, if your not in a hurry then you may want to check out the TF heads when they become available, if they did their homework on the smallblock heads like they did on the Bigblock heads then they will be a nice street/strip deal.
