Is that Bondo in the roof rail channel?? #2586319
12/02/18 09:34 PM
12/02/18 09:34 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
Getting ready to put the new vinyl top on the 69 Charger. It looks like bondo in the window channel drip rail...and its all cracked up and missing chunks. Is that just Bondo that I need to replace, or should I just remove it all and clean up the drip rail? If I remove it, will the vinyl top look to sit down too far in the channel and not look right? Hope to hear what you did when replacing your top. Thanks!
Dave in Colorado
Re: Is that Bondo in the roof rail channel?? [Re: dssaa] #2586321
12/02/18 09:38 PM
12/02/18 09:38 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
It should be body seam sealer.
Sheldon
Re: Is that Bondo in the roof rail channel?? [Re: RUNCHARGER] #2586349
12/02/18 10:27 PM
12/02/18 10:27 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
I believe you are correct....it just looks like old bondo due to age? I am going to the parts store now to get sealer....Thanks!
Re: Is that Bondo in the roof rail channel?? [Re: dssaa] #2586773
12/03/18 09:21 PM
12/03/18 09:21 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Yes it's seam sealer like what was also used in the trunk it's just finished nicer
Re: Is that Bondo in the roof rail channel?? [Re: Morty426] #2586774
12/03/18 09:31 PM
12/03/18 09:31 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Give it some time to dry and shrink down before installing the top.
Re: Is that Bondo in the roof rail channel?? [Re: dssaa] #2589202
12/08/18 11:48 PM
12/08/18 11:48 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
There are some two-part catalyzed seam sealers available now.They may help expedite your vinyl install,Lord Fusor is one manufacturer.Look at #122EZ in the list,i couldn't copy the individual part description for some reason.
https://www.lord.com/products-and-soluti...ontrol-products
Re: Is that Bondo in the roof rail channel?? [Re: dssaa] #2589222
12/09/18 12:53 AM
12/09/18 12:53 AM
USA
hudsonhornet7x Offline
USA
A little advice if you are asking:
RTS runner has the right Idea here. I have been a bodyman most of my life and here it what I would do:
Remove all of the old seam sealer
Clean up any rust in the area
Apply a 2K seam sealer. I prefer the 3M Impact Resistant Structural Adhesive IRSA for 3 reasons.
1. It is epoxy based and will work as good or better as epoxy primer
2. It has a long work time to tool it and let it flow out.
3. It changes color when curing so you know the stuff is ready to go.
Hope this helps. By the way, IRSA is a structural adhesive that works great as a seam sealer too.
Re: Is that Bondo in the roof rail channel?? [Re: hudsonhornet7x] #2595573
12/22/18 07:15 PM
12/22/18 07:15 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Stupid question, do you stuff the vinyl top into the adhesive before it sets up or do you let it set up and then glue the top down?
Re: Is that Bondo in the roof rail channel?? [Re: 6PakBee] #2596679
12/25/18 11:18 AM
12/25/18 11:18 AM
Milan Ohio
ct440rod Offline
ct440rod  Offline
Milan Ohio
Let it dry
