727 and valve body id question? #2584135
11/28/18 01:05 PM
11/28/18 01:05 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
Bought a 727 trans for a guy from work and he claims it has a reverse manual valve body in it. I have never seen one with a Chrysler part number on it. Can anyone help id the trans year and valve body. The trans has no vin stamped on it. The trans numbers are 3878001 M4977 8798. The valve body is 37431559. He swears the trans was rebuilt by Mancinni Racing years ago. Thanks for any help.
Re: 727 and valve body id question? [Re: maximus] #2584176
11/28/18 02:42 PM
11/28/18 02:42 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Turbo action cheetah valve bodies are reworked originals. Look on the separator plate and it will have writing on it with an engraver. That plate is the thin metal plate between the two halves.
Re: 727 and valve body id question? [Re: NANKET] #2584194
11/28/18 03:16 PM
11/28/18 03:16 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
The valve body plate only has the number 373 punched through it.
Re: 727 and valve body id question? [Re: maximus] #2584521
11/29/18 02:25 AM
11/29/18 02:25 AM
Cedar Rapids, IA
69Mcode440 Offline
69Mcode440  Offline
Cedar Rapids, IA
According to CRT's website that number is a 1975 trans.
Mike
69 440 Cuda
71 Dart drag car
70 Duster drag car Best et 9.32, 145.9 mph
2019 Ram 2500 4x4
Re: 727 and valve body id question? [Re: maximus] #2584553
11/29/18 04:12 AM
11/29/18 04:12 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
mopar made and sold all parts to make a manua vb for years .
it would have no special pn stamped on it .
look at the shaft for throttle preasure .
if it is cut off just above the snap ring or if it moves freely full travel with no resistance it would most likely be a manual vb.
Re: 727 and valve body id question? [Re: calrobb2000] #2584588
11/29/18 10:46 AM
11/29/18 10:46 AM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
The seller claimed it is a REVERSE manual valve body. How can you tell the difference between forward and reverse vb id.
Re: 727 and valve body id question? [Re: maximus] #2584735
11/29/18 03:54 PM
11/29/18 03:54 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Not everybody cuts of the TP lever shaft when building a MVB; look at the throttle valve, if it extends from its bushing and moves under spring resistance, it's not a MVB but if it's below the level of the bushing, like in the pic below, it's a MVB.
Your spring retainer and lever stop will look different but the end of the valve will be the same.
Re: 727 and valve body id question? [Re: John_Kunkel] #2584759
11/29/18 04:38 PM
11/29/18 04:38 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
OK the tp has been cut down. So it is safe to assume it is converted to manual shift. The question remains is it still forward shift or reverse pattern? All my shifters are for reverse pattern shifting. Thank for all the help so far.
Re: 727 and valve body id question? [Re: maximus] #2585831
12/01/18 09:27 PM
12/01/18 09:27 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
"The valve body plate only has the number 373 punched through it."
The "373" plate is a separator plate sold thru the old direct connection program which converts a stock VB into a REVERSE MANUAL. Along with the plate, you needed to mill passages in the transfer plate, remove all the check balls except the large 11/32" ball, and remove the shift springs and block the governor plugs with 1/4" round stock. Refer to the old Direct Connection racing manual for details.
http://www.moparts.org/Tech/Archive/auto/18/bulletin18a,p16,trans.JPG
http://www.moparts.org/Tech/Archive/auto/img/bulletin_19_torqueflitemods_12.jpg
John Kunkel has a pic of the transfer plate with the milled walls.
Hope that answers your question.
Re: 727 and valve body id question? [Re: DusterW2] #2585845
12/01/18 09:58 PM
12/01/18 09:58 PM
Rio Linda, CA
Rio Linda, CA
Here's a pic of the mods to the '71-later transfer plate, the red areas are where the channel wall is removed. The red circle mod is not factory.
Re: 727 and valve body id question? [Re: John_Kunkel] #2585858
12/01/18 10:27 PM
12/01/18 10:27 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
That is exactly what the one I have looks. Thanks for all the help. I needed to know if it was a reverse manual vb.
