Re: 727 and valve body id question?
[Re: maximus]
#2584521
11/29/18 02:25 AM
11/29/18 02:25 AM
Posts: 89 Cedar Rapids, IA
69Mcode440
Cedar Rapids, IA
According to CRT's website that number is a 1975 trans.
Mike 69 440 Cuda 71 Dart drag car 70 Duster drag car Best et 9.32, 145.9 mph 2019 Ram 2500 4x4
[Re: maximus]
#2584735
11/29/18 03:54 PM
11/29/18 03:54 PM
Posts: 25,887 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Not everybody cuts of the TP lever shaft when building a MVB; look at the throttle valve, if it extends from its bushing and moves under spring resistance, it's not a MVB but if it's below the level of the bushing, like in the pic below, it's a MVB.
Your spring retainer and lever stop will look different but the end of the valve will be the same.
[Re: maximus]
#2585831
12/01/18 09:27 PM
12/01/18 09:27 PM
Posts: 1,812 Portsmouth, VA
DusterW2
Portsmouth, VA
"The valve body plate only has the number 373 punched through it." The "373" plate is a separator plate sold thru the old direct connection program which converts a stock VB into a REVERSE MANUAL. Along with the plate, you needed to mill passages in the transfer plate, remove all the check balls except the large 11/32" ball, and remove the shift springs and block the governor plugs with 1/4" round stock. Refer to the old Direct Connection racing manual for details. http://www.moparts.org/Tech/Archive/auto/18/bulletin18a,p16,trans.JPG http://www.moparts.org/Tech/Archive/auto/img/bulletin_19_torqueflitemods_12.jpgJohn Kunkel has a pic of the transfer plate with the milled walls. Hope that answers your question.
[Re: DusterW2]
#2585845
12/01/18 09:58 PM
12/01/18 09:58 PM
John_Kunkel
Rio Linda, CA
Here's a pic of the mods to the '71-later transfer plate, the red areas are where the channel wall is removed. The red circle mod is not factory.
