Parachute induced puke #2584993
11/30/18 01:09 AM
11/30/18 01:09 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
Ok so i was going a bit faster & had to upgrade to a chute so i could stop in time. Now that im feeling that blooming chute jolt, my vac pump catch can is now filling up & spewing oil out of the puke can breather. Its kinda making things around it look a bit messy so what do you chute pullers do to prevent the puke. My vac pump pulls from my rocker covers from the front, this wasnt much of an issue when i was just stomping on a pedal, but now that im letting the laundry loose we've created a nightmare. Ideas to fix please.
Re: Parachute induced puke [Re: rebel] #2585001
11/30/18 01:31 AM
11/30/18 01:31 AM
Put a solid baffle in front of the open end of the fitting in the valve overs so it won't suck the oil into the pump or move the fitting where it can only suck air into the pump scope twocents
Re: Parachute induced puke [Re: rebel] #2585012
11/30/18 02:10 AM
11/30/18 02:10 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
Well i have baffles at the outlet of the covers already & i dont really want to drill more holes in the covers than i need to
Re: Parachute induced puke [Re: rebel] #2585044
11/30/18 04:01 AM
11/30/18 04:01 AM
A727Tflite Online content
A727Tflite  Online Content
Are you pulling the chute while in the throttle or off throttle?
Re: Parachute induced puke [Re: A727Tflite] #2585049
11/30/18 05:13 AM
11/30/18 05:13 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
Off. My chute takes about 3 seconds to become fully bloomed & then its like youve reached the end of the bungy, it pulls up really fast.
Re: Parachute induced puke [Re: rebel] #2585056
11/30/18 08:21 AM
11/30/18 08:21 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Aren't you meant to drive into the chute ?
Thats what a mate who needs one told me .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Parachute induced puke [Re: tex013] #2585112
11/30/18 12:13 PM
11/30/18 12:13 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i had the same prob,moved my line to the rear of the rocker cover and solved the prob.
Re: Parachute induced puke [Re: rebel] #2585127
11/30/18 12:35 PM
11/30/18 12:35 PM
crabman173
crabman173
Stroud chutes open nice and soft and you can pack them drunk and they still work great--best out there
Re: Parachute induced puke [Re: rebel] #2585187
11/30/18 02:39 PM
11/30/18 02:39 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I tried multiple locations, only one that worked right ..
Middle of valve cover , towards the rear of it , right above the rail
It would pull maybe a tea spoon a pass 10hg on the gauge with 2 shims taken out
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Parachute induced puke [Re: rebel] #2585302
11/30/18 06:55 PM
11/30/18 06:55 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Sounds like way too much oil to the top end !!
Re: Parachute induced puke [Re: rebel] #2585311
11/30/18 07:12 PM
11/30/18 07:12 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Splitting the line with a tee and going into both covers helps, but it sounds like you need some drain back lines back to the pan on your heads.
Re: Parachute induced puke [Re: Stanton] #2585320
11/30/18 07:38 PM
11/30/18 07:38 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Took the words out of my fingers.
Re: Parachute induced puke [Re: CMcAllister] #2585331
11/30/18 08:17 PM
11/30/18 08:17 PM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
possibly. it's an Indymaxx block & they dont have huge holes for oil to return from the valley. I have opened them up & contoured the openings to improve drainage. Before we ran a chute we would see maybe 10-15cc's of oil in the puke can breather. So i can't change the block anymore than i have & we don't have a lack of oil problem at the pick up, so i'm looking into an air/oil seperator to fit before the pump. anyone got one of them?
Re: Parachute induced puke [Re: rebel] #2585349
11/30/18 08:57 PM
11/30/18 08:57 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
I once did an engine for a guy who had someone else build it before he sent it to me. It had dripping oil out of the headers! I discovered it didn't have an orifice in the supply lines. Pumping way too much oil up top!
Re: Parachute induced puke [Re: tjmarcus1] #2585485
12/01/18 12:56 AM
12/01/18 12:56 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
[quote=tjmarcus1] I discovered it didn't have an orifice in the supply lines. Pumping way too much oil up top! [/quote
Being -1heads i have restrictors on both sides @ I'm using -3 lines for the feed. I think i got this one.
Re: Parachute induced puke [Re: rebel] #2586917
12/04/18 05:52 AM
12/04/18 05:52 AM
aotearoa
rebel Offline OP
rebel  Offline OP
aotearoa
Ok so i didnt really get a definative answer so i went n bought a Moroso air/oil seperator. Be interesting to see if it works. Only problem, no racing til new years at the local track
