Re: Parachute induced puke
[Re: rebel]
#2585056
11/30/18 08:21 AM
11/30/18 08:21 AM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
Off. My chute takes about 3 seconds to become fully bloomed & then its like youve reached the end of the bungy, it pulls up really fast. Aren't you meant to drive into the chute ? Thats what a mate who needs one told me . Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: rebel]
#2585127
11/30/18 12:35 PM
11/30/18 12:35 PM
crabman173
crabman173
Stroud chutes open nice and soft and you can pack them drunk and they still work great--best out there
[Re: rebel]
#2585187
11/30/18 02:39 PM
11/30/18 02:39 PM
Posts: 34,909 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I tried multiple locations, only one that worked right ..
Middle of valve cover , towards the rear of it , right above the rail
It would pull maybe a tea spoon a pass 10hg on the gauge with 2 shims taken out
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: rebel]
#2585311
11/30/18 07:12 PM
11/30/18 07:12 PM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
Splitting the line with a tee and going into both covers helps, but it sounds like you need some drain back lines back to the pan on your heads.
[Re: Stanton]
#2585320
11/30/18 07:38 PM
11/30/18 07:38 PM
Posts: 11,578 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Sounds like way too much oil to the top end !! Took the words out of my fingers.
[Re: CMcAllister]
#2585331
11/30/18 08:17 PM
11/30/18 08:17 PM
Posts: 4,647 aotearoa
rebel
aotearoa
Sounds like way too much oil to the top end !! Took the words out of my fingers. possibly. it's an Indymaxx block & they dont have huge holes for oil to return from the valley. I have opened them up & contoured the openings to improve drainage. Before we ran a chute we would see maybe 10-15cc's of oil in the puke can breather. So i can't change the block anymore than i have & we don't have a lack of oil problem at the pick up, so i'm looking into an air/oil seperator to fit before the pump. anyone got one of them?
