Brass float vs plastic, which one? #2583104
11/26/18 02:06 AM
11/26/18 02:06 AM
BlueRacer69 Offline OP
Hi fellow members. Which type of gas tank float works better, last longer with today's crappy gas? Brass or plastic. Or does it not matter that much. Thanks for your opinions.
Re: Brass float vs plastic, which one? [Re: BlueRacer69] #2583179
11/26/18 01:00 PM
11/26/18 01:00 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Seeing what ethanol does to parts and without knowing what type of plastic resin is used to make floats, I use the brass floats when I can. Someone more in the know than me may have a reason to say otherwise.
Re: Brass float vs plastic, which one? [Re: BlueRacer69] #2583205
11/26/18 02:01 PM
11/26/18 02:01 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I prefer the brass ones as well, however I have used the phenolic ones with ethanol fuel without problems.
Re: Brass float vs plastic, which one? [Re: BlueRacer69] #2583219
11/26/18 02:49 PM
11/26/18 02:49 PM
Olympia, Washington
tallzag Online content
tallzag  Online Content
Olympia, Washington
Brass - any kind of plastic just doesn't hold up well to ethanol. The price difference is negligible between brass and plastic.
Rocket Restorations
Re: Brass float vs plastic, which one? [Re: tallzag] #2583262
11/26/18 03:43 PM
11/26/18 03:43 PM
moparx Offline
moparx  Offline
and, if my old feeble mind recalls what i remember, there is a ford float that is cheaper than the mopar one, and it fits the swing arm perfectly. it "may" be for a 70's ford pickup, but i'm not sure on that.
others here may have a better memory than me. biggrin [wouldn't be much effort for that to be true]
beer
Re: Brass float vs plastic, which one? [Re: BlueRacer69] #2583268
11/26/18 03:55 PM
11/26/18 03:55 PM
Nanuet, NY
johntpr Offline
johntpr  Offline
Nanuet, NY
Ford part # COAZ-9202-B
69 Daytona 4 speed
Re: Brass float vs plastic, which one? [Re: johntpr] #2583281
11/26/18 04:20 PM
11/26/18 04:20 PM
Get an american made one even if it is a furd (overseas solder can be a problem)
Re: Brass float vs plastic, which one? [Re: tallzag] #2583349
11/26/18 07:17 PM
11/26/18 07:17 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
You may want to research this a little more. I run alcohol and wouldn’t run brass floats if you gave them to me
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Brass float vs plastic, which one? [Re: pittsburghracer] #2583483
11/27/18 12:17 AM
11/27/18 12:17 AM
^^^ That jogged a memory of a conversation I had with John at "the carburetor shop" who lives/breathes carbs & he said nitro floats give more control & are lighter & to beware of overseas brass floats cuz the solder is substandard & can fail. He did mention something about ethanol but since I ain't running it I did not write it down (& dont remember it). This was regarding a circle track Rochester 2bbl FWIW.
Re: Brass float vs plastic, which one? [Re: BlueRacer69] #2583533
11/27/18 02:11 AM
11/27/18 02:11 AM
Are the brass floats that Ford sells made here in the USA or overseas. Anybody know? Thanks.
Re: Brass float vs plastic, which one? [Re: BlueRacer69] #2583549
11/27/18 02:54 AM
11/27/18 02:54 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Most gas tank floats are made from Polypropylene/Polyethylene family plastics which are impervious to most chemicals including gas, alcohol, and fuels in general. Same plastic fuel jugs are made from.
Re: Brass float vs plastic, which one? [Re: ScottSmith_Harms] #2583641
11/27/18 12:38 PM
11/27/18 12:38 PM
Thanks Scott, I didn't realize that. up
Re: Brass float vs plastic, which one? [Re: BlueRacer69] #2583668
11/27/18 01:54 PM
11/27/18 01:54 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
For what it's worth, the only 2 floats I have ever had "sink" were brass. I have never had a plastic one leak on me.
Your experience may vary.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
