Push rod oiling #2582163
11/23/18 11:54 PM
11/23/18 11:54 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
Can you have too much oil to the pushrod cup? The hydraulic roller lifters I'm looking at for my cam change have pushrod oiling and I was wondering what pushrods to order. I don't have any adjuster cup issues right now but my new cam profile is a little more aggressive than my current solid flat cam.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Push rod oiling [Re: fourgearsavoy] #2582174
11/24/18 12:13 AM
11/24/18 12:13 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
When I sent oil up just the exhaust PR on a gen 2 with no hole in the adjuster 15 lbs of OP was lost.Did my friends wedge with all 16 PR with no oil hole in the adjuster and also lost 15 lbs of OP.Use a 20 or 30 thou restrictor and the op came right back.
I think it is good as the wedge cups tend to burn in particular cases.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Push rod oiling [Re: fourgearsavoy] #2582175
11/24/18 12:13 AM
11/24/18 12:13 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have the Morel high rpm hydro rollers in my 512, my push rods are for oiling & also the stock timed rocker oiling, I did this instead of grooving the cam for full time rocker oiling, 2k miles & some track, good so far.
Re: Push rod oiling [Re: fourgearsavoy] #2582210
11/24/18 01:39 AM
11/24/18 01:39 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
I've been thinking about using pushrod oiling just for the cups and still use the regular rocker shaft oiling. That means using restrictors -does it make a difference on which end (or both) of the pushrod I put in the restrictors? Or can I get pushrods with smaller than usual oiling holes (so that no restrictor is needed)? I'd like to use Manton or Trend pushrods.
Re: Push rod oiling [Re: fourgearsavoy] #2582240
11/24/18 02:56 AM
11/24/18 02:56 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I had Manton make my pushrods and went with .020 restrictors.......still brings plenty of oil to the top end.
I oriented the restrictors to the bottom ( lifter side ) just because according to my best guess , any additional weight would have less impact from down there.
Re: Push rod oiling [Re: fourgearsavoy] #2582300
11/24/18 12:11 PM
11/24/18 12:11 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Think about most Indy heads feed 8 valves from a .040" orifice. The area of 8 .020" feeds far exceeds that. The pushrods I inherited were .090". Oil pressure never went over 45lbs. After a few tries I ended up pressing roll pins into the pushrods. There are approximately .058". larger feed than I would like, but oil pressure is manageable now. Runs 70psi@7000.
Doug
