Page 3 of 3 1 2 3
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2581367
11/22/18 01:12 AM
11/22/18 01:12 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
So the setup posted in the picture above worked, it for sure had some lost resolution from when I had it on the driveshaft with my 8.75. Going from 8 pickup points on the driveshaft to 5 on the wheel did make a noticeable difference in the logs. It also had a small bump in the log I couldn't get out, likely because the wheel studs are not machined perfect and one of them was probably a little out of range of the sensor.
It was driving me crazy so I bought a kit from Motion RaceWorks, they have a combo of Strange Yoke with a tone ring, sensor, and sensor bracket. I already have a few of the sensor they use so they dropped that off the price and added their black friday discount a week early.
https://www.motionraceworks.com/products...rol-for-dana-60
The 16 points of resolution on the driveshaft yoke should be super smooth.
68 Barracuda Formula S 340
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2581377
11/22/18 01:33 AM
11/22/18 01:33 AM
AndyF Offline
AndyF  Offline
This is the setup I used in my Duster. I made some extra brackets in case other guys want to run the same parts. I designed this bracket for a Dana 60 but it might work on a 8 3/4 with some modifications.
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2581380
11/22/18 01:38 AM
11/22/18 01:38 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That is nice Andy but I don't have the pinion snubber pads like the S60 has. This is just some random pickup truck Dana that I had cut down.
Re: Racepak and 8 3/4???? Driveshaft sensor mount?? [Re: DemonDust] #2581382
11/22/18 01:43 AM
11/22/18 01:43 AM
AndyF Offline
AndyF  Offline
Yeah, the snubber bolt holes are handy for holding a sensor bracket. That is one drawback to using a truck rearend.
Page 3 of 3 1 2 3
