Trick Flow 240 Heads #2581285
11/21/18 10:03 PM
11/21/18 10:03 PM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
Looking at these Trick Flow 240 heads. Planned use is a strong street RB engine at the 600 hp level. Difference between there several offerings is spring diameter, retainer material and retainer degrees. What is the best use for street use, 7 or 10 degree retainers? Also, wtth the angled plug design, what headers work best?
Re: Trick Flow 240 Heads [Re: RROD] #2581309
11/21/18 10:54 PM
11/21/18 10:54 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I like the 10* retainer/lock's myself,, I run the Hedman Hustler fenderwell headers myself, but not for street use, so I cannot help you there.
Re: Trick Flow 240 Heads [Re: RROD] #2581324
11/21/18 11:24 PM
11/21/18 11:24 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
IMO
7 or 10 will be fine street strip
I have the steel retainer mid level spring , dual spring,on TF270s .
I use Dougs D452 headers , great fit .
In a 68 Plymouth B body
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Trick Flow 240 Heads [Re: tex013] #2581339
11/21/18 11:44 PM
11/21/18 11:44 PM
birdtracker Offline
birdtracker  Offline
buy the heads with the plan already in place to install the recommended spring for your camshaft. The locks and retainers are good quality, but trying to get by with springs already on them 90 percent of the time won't work out after everything is checked.Birdtracker
Re: Trick Flow 240 Heads [Re: RROD] #2581341
11/21/18 11:48 PM
11/21/18 11:48 PM
AndyF Offline
AndyF  Offline
The different spring choices are so you can match up with the type of cam that you want to run. Flat tappet, hyd roller or solid roller. Once you know the type of cam then pick the head that matches.
Re: Trick Flow 240 Heads [Re: AndyF] #2581568
11/22/18 04:08 PM
11/22/18 04:08 PM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
Thanks for the good information.
Re: Trick Flow 240 Heads [Re: RROD] #2581584
11/22/18 04:38 PM
11/22/18 04:38 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Hedman 78030's are a reasonably priced quality header that fits most B/E body applications and work well with standard port location BB heads.
'63 Dodge 330
11.19 @ 121 mph
Re: Trick Flow 240 Heads [Re: RROD] #2581632
11/22/18 06:39 PM
11/22/18 06:39 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
I have the Hedman 78030's on my currently iron-headed (straight plug) 451. I don't see any way they will work with an angle-plug head.
