Trick Flow 240 Heads
#2581285
11/21/18 10:03 PM
11/21/18 10:03 PM
Posts: 547 Minnesota
RROD
Minnesota
Looking at these Trick Flow 240 heads. Planned use is a strong street RB engine at the 600 hp level. Difference between there several offerings is spring diameter, retainer material and retainer degrees. What is the best use for street use, 7 or 10 degree retainers? Also, wtth the angled plug design, what headers work best?
Re: Trick Flow 240 Heads
[Re: RROD]
#2581309
11/21/18 10:54 PM
11/21/18 10:54 PM
dartman366
Mt. Vernon, Ohio
I like the 10* retainer/lock's myself,, I run the Hedman Hustler fenderwell headers myself, but not for street use, so I cannot help you there.
[Re: RROD]
#2581324
11/21/18 11:24 PM
11/21/18 11:24 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
IMO 7 or 10 will be fine street strip I have the steel retainer mid level spring , dual spring,on TF270s . I use Dougs D452 headers , great fit . In a 68 Plymouth B body
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: RROD]
#2581584
11/22/18 04:38 PM
11/22/18 04:38 PM
Posts: 4,684 Wichita
GY3
Wichita
Hedman 78030's are a reasonably priced quality header that fits most B/E body applications and work well with standard port location BB heads.
