70RR Headlight buzzer? #2579134
11/16/18 01:35 PM
11/16/18 01:35 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Are these available....
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 70RR Headlight buzzer? [Re: JMCFAN] #2580737
11/20/18 07:17 PM
11/20/18 07:17 PM
Chicago
PurpleBeeper Offline
Chicago
Hmmm.... I "thought" only the key had the buzzer, but what do I know??? Mine isn't working and I got really lucky a couple years ago and found an OEM buzzer on e-bag, but haven't installed it yet.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 70RR Headlight buzzer? [Re: PurpleBeeper] #2581020
11/21/18 12:59 PM
11/21/18 12:59 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
You may be correct.. just had my dash wired a note says needs headlight buzzer...
Re: 70RR Headlight buzzer? [Re: JMCFAN] #2581073
11/21/18 02:38 PM
11/21/18 02:38 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
there was a "RARE" OPTION for the '70 b-body,
L42 - $18.20 "headlight time delay & warning signal"
less than 100 installed on the almost 42,000 Road Runners for 1970
Re: 70RR Headlight buzzer? [Re: JMCFAN] #2581269
11/21/18 09:28 PM
11/21/18 09:28 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
They are available on Ebay.
Re: 70RR Headlight buzzer? [Re: 70HemiGTX] #2581291
11/21/18 10:19 PM
11/21/18 10:19 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
wow....jut unplug it....???
https://www.ebay.com/itm/NOS-MOPAR-70-GT...ER/253967766519
Re: 70RR Headlight buzzer? [Re: JMCFAN] #2581310
11/21/18 10:55 PM
11/21/18 10:55 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
There are cheaper ones listed.
Re: 70RR Headlight buzzer? [Re: JMCFAN] #2581313
11/21/18 10:59 PM
11/21/18 10:59 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I'm not sure, but I think you need the headlight delay harness for it to work with the headlights. If you don't it will only work with the key buzzer. I will look at my dash tomorrow to see how it is wired.
Re: 70RR Headlight buzzer? [Re: 70HemiGTX] #2581343
11/21/18 11:51 PM
11/21/18 11:51 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Thanks!!!
Re: 70RR Headlight buzzer? [Re: JMCFAN] #2581508
11/22/18 01:40 PM
11/22/18 01:40 PM
New York
rarefish Offline
rarefish  Offline
New York
20 years ago I sold my 71 GTX that had the L42 Headlamp Time Delay W/Warning Signal option. The cost then was $19.45
Only 30 GTXs had the option in 1971
Re: 70RR Headlight buzzer? [Re: rarefish] #2581609
11/22/18 05:50 PM
11/22/18 05:50 PM
MetroWest, MA.
BeeOrange Offline
BeeOrange  Offline
MetroWest, MA.
My 70 Super Bee has a buzzer if the lights are left on after the ignition is turned off. I believe it is part of the light package. I think the ignition time delay is a stand alone option.
70 Super Bee FK5 383 4-Speed
68 GTX RR1 426 Auto
70 Cuda FC7 440 Auto
Psalm 37:5: Commit your way to the Lord; trust also in Him and He will do it
Re: 70RR Headlight buzzer? [Re: BeeOrange] #2581710
11/22/18 10:19 PM
11/22/18 10:19 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I had a chance to look at my dash today, but not enough time to really sort out where all wires go. Hopefully over the weekend I can do that and get some pics for you.
Re: 70RR Headlight buzzer? [Re: JMCFAN] #2582043
11/23/18 06:36 PM
11/23/18 06:36 PM
Chicago
Chicago
No kidding? I have that option.... wish it was the Hemi engine option, but I'll take what I got.
Re: 70RR Headlight buzzer? [Re: JMCFAN] #2583607
11/27/18 10:50 AM
11/27/18 10:50 AM
VA
dragon slayer Offline
VA
If you look at the diagram in wiring section of SM you can see the harnesses. The Key buzzer is stand alone. Add a Diode harness in to one of the connectors and now the Head Light buzzer is on. Add another harness with a thermal switch (Small Can) and Head Light delay is added.
There were several different buzzers and the wiring switched around from 69 to 70 so you need to ensure you get the right part. Lots of different part numbers and depending on how it is internally wired can cause issues. Also internally pretty easy to get the coil wire damaged. So purchasing can be problematic.
Been messing with it on my 70RR and get weird reactions. The stand alone key buzzer will come on when you open the door even if motor running, so the buzzer is not turned off when ignition is hot.
Added a diode harness and had similar issues with lights, including it was feeding back when light on. The ignition would not go off even if the key was turned off. Had to turn light off to shut motor off? Really weird. Anyway pulled diode harness out, and it functions except that any door opening regardless of ignition switch position has the buzzer go off. Other than key out.
I can see why so many just pulled the buzzer in the day.
