904 Rear servo spring. #2579436
11/17/18 03:20 AM
11/17/18 03:20 AM
Aus
hysteric Offline OP
hysteric  Offline OP
Aus
I went with the the fairbanks shift kit and the spring they provide for the reverse low servo is too big to fit the billet A&A servo. The strange thing about it is the the 3 coil spring does feels stiffer than the 6 coil spring provided in the fairbanks kit.
Is stiffer better? I'm going for the full manual set up.
Or should i find a replacement spring?
Re: 904 Rear servo spring. [Re: hysteric] #2579649
11/17/18 08:10 PM
11/17/18 08:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Stiffer spring makes the rear band release quicker on the 1-2 upshift if you have LBA.
Re: 904 Rear servo spring. [Re: hysteric] #2580287
11/19/18 06:16 PM
11/19/18 06:16 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I use the stock spring and servo and have no issues with the 1-2 shift.
Re: 904 Rear servo spring. [Re: hysteric] #2580297
11/19/18 06:55 PM
11/19/18 06:55 PM
Aus
hysteric Offline OP
hysteric  Offline OP
Aus
Interesting. Do you have a shift kit or manual valve body in your's Humpty?
Re: 904 Rear servo spring. [Re: humpty] #2580350
11/19/18 09:51 PM
11/19/18 09:51 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You do, you just don't notice it.
Re: 904 Rear servo spring. [Re: hysteric] #2580432
11/20/18 12:54 AM
11/20/18 12:54 AM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I run an A&A low band apply manual valve body with a trans brake.
John K - this tranny hits harder in every gear than any other trans I've owned. In my experience the 2-3 shift has proven more of an issue than the 1-2.
Re: 904 Rear servo spring. [Re: hysteric] #2580507
11/20/18 04:19 AM
11/20/18 04:19 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
We put an A & A reverse manual valve body in my sons Dart and used the A & A rear servo piston and spring. He recommended we use it as its a low band apply valve body we put in my boys Dart. We cant notice any different in the 1-2 shift and the car did not slow down any. And the old valve body was a no low band apply. Ron
